speed (180+)
08.05.2020 16:12 # 1
Muhammet
First of all, pleasant forums and in addition, I would like to point out that I would also warn those who do not speed up where we stopped and endanger the lives of others in traffic. Anyway let's come to my question. On the way back from school today, the road was empty and I had never fully tested the vehicle in speed. I started to press after 90 (between 5000-7000 dd) 150-160 when I came up to 180, although it was downhill, it started to rise from 180 to very, very slowly. the draft of the vehicle is shaking and the rot adjustment needs to be adjusted, after the rot is made, will this be corrected, or if this is the case?
08.05.2020 16:12 # 2
Tremor is about balance. Tires need to be balanced. & Nbsp;
08.05.2020 16:12 # 3
istanbullu_3886
[QUOTE = Muhammet] first of all pleasant forums and in addition, I would like to point out that I would also warn those who do not speed up where I stand and endanger the lives of others in traffic. Anyway let's come to my question. On the way back from school today, the road was empty and I had never fully tested the vehicle in speed. I started to press after 90 (between 5000-7000 dd) 150-160 when I came up to 180, although it was downhill, it started to rise from 180 to very, very slowly. the draft of the vehicle is shaking and the rot adjustment needs to be adjusted. Will this be corrected after the rod is made, or if this is the case, we burned 2.0 engine in the vehicle 190 is not blocked, right?
[/ QUOTE] I SAID 175 IN 3500 RPMS
08.05.2020 16:12 # 4
Muhammet
Today, after selling the old vehicle, my first job will be balancing and taking it to the rot. I wonder if it will recover after they are made (ie acceleration after 180)
< / div>
08.05.2020 16:12 # 5
Muhammet
[QUOTE = istanbullu_3886] [QUOTE = Muhammet] First of all, I would like to state that there are pleasant forums and in addition I would warn those who do not speed up to stop the traffic and endanger the lives of others. Anyway let's come to my question. On the way back from school today, the road was empty and I had never fully tested the vehicle in speed. I started to press after 90 (between 5000-7000 dd) 150-160 when I came up to 180, although it was downhill, it started to rise from 180 to very, very slowly. the draft of the vehicle is shaking and the rot adjustment needs to be adjusted. Will this be corrected after the rod is made, or if this is the case, we burned 2.0 engine in the vehicle 190 is not blocked, right?
[/ QUOTE] I SAID 175 IN 3500 RPMS KADDEN [/ QUOTE]
is true master but my vehicle is 4 gears. mine is only 140 in 3500 rpm & nbsp; "Laugh"
08.05.2020 16:12 # 6
metin
It shouldn't stay in 190, I made a speed for a short time to try it with my 1.6 automatic vehicle. After 195 I slowed down. I wonder if your engine may not have been turned on,
08.05.2020 16:12 # 7
istanbullu_3886
[/ QUOTE] I SAID 175 IN 3500 RPM KADESH [/ QUOTE] I did not go very fast when I went to Kayseri from Istanbul. I did not make much speed in my car, I got a little tightened when I came back, I went to Kırklaelin one day after I came, I saw 175 km speed at 3500 rpm.
08.05.2020 16:12 # 8
Muhammet
[QUOTE = text] It shouldn't stay in 190, I made speed for a short time to try it with my 1.6 automatic vehicle. After 195 I slowed down. I wonder if your engine may not have been turned on, [/ QUOTE]
i 1.6 civic Si is a light vehicle with my car, but I was knocking the needle, this is clogged in 190. I don't know if it might not have been opened but I don't think it was because the person I bought was young, of course, how did I open the engine if it wasn't opened?
08.05.2020 16:12 # 9
DRIVER34
Though I still have the current balance at 140-150 at the steering wheel, it starts to show itself when it exceeds 130, though 14 16v car but I couldn't go over 180 yet, both without shaking and the road was not available anyway .. but it did not improve with balance .. & nbsp;
08.05.2020 16:12 # 10
Friends, I think that if the tires have different patterns or the front and the back are different, the same problem will be the same.
08.05.2020 16:12 # 11
DRIVER34
[QUOTE = HeRo1727] Friends I think it will have the same problem if the tires are different with different patterns or front and back. mıchelın energy saver was taken at the same time for 2 years, the depth of the tooth is untouched 5.1 car 73 thousand when I first tried it was 65000 ... I suspect the tire weather, but I think the rot adjustment will be done a little bit & nbsp; left pull is in the car
08.05.2020 16:12 # 12
Muhammet
[QUOTE = HeRo1727] Friends I think it will have the same problem if the tires are different with different patterns or front and back. The vehicle may not turn on but you have to know km ... [/ QUOTE]
has been 5 days since the tires I do not remember the brand of four 4-season tires, the vehicle is at 108.000 km
08.05.2020 16:12 # 13
Muhammet
[QUOTE = DRIVER34] [QUOTE = HeRo1727] Friends, I think it will have the same problem if the tires have different patterns or front and back.
4 tires michel's energy saver was taken at the same time, 2 years untouched tread depth 5.1 cars 73,000 thousand times when I first tried it, I suspect tire weather, I checked them too but I think rot adjustment will be done a little bit & nbsp; there is a pull on the left < / div> [/ QUOTE]
rot tandır master, slightly right on my vehicle I'm shooting (if I go) I'll let me know if I get it done today
08.05.2020 16:12 # 14
The direction of the tires may be in the correct direction, if it is not installed correctly, the car should not remain in my mind at 190.
08.05.2020 16:12 # 15
DRIVER34
& nbsp; [QUOTE = Muhammet] [QUOTE = DRIVER34] [QUOTE = HeRo1727] Friends, I think it will have the same problem if the tires have different patterns or front and back different.
4 tires michel's energy saver was taken at the same time, 2 years untouched, tread depth was 5.1 cars when it was the first attempt at 73 thousand and it was 65000 ... & nbsp; left pull in the car
rot tandır master, my vehicle pulls a little to the right, let's see if I get better this day (if I go) I'll let me know if it gets better. . & nbsp;
Let's go prepared with the indication of the cost of
& nbsp; "Blink" & nbsp; we have: D
08.05.2020 16:12 # 16
Muhammet
Well, 25 TL to the rotter, 40 TL to the rotary. I hope nothing will happen, let's see now.
08.05.2020 16:12 # 17
The weight of the vehicle should be kept in mind. It should not be less than 1500 kg. We do not know how to maintain the engine. It can also be used in the proposal. Anyway, because it is a vehicle that burns a lot of gas, too much smiley can be seen.
08.05.2020 16:12 # 18
34sea45
I think that the engine should not be deaf in 190. Even my 1.4 75 hp vehicle knocks the needle (it started to click on the km stick after I had the mode turned before my vehicle had mode).
nice :)
08.05.2020 16:12 # 19
[QUOTE = 34sea45] I think that engine should not stay deaf 190 even 1.4 75 hp my car knocks the needle (it started to click on the km stick after I had the mode turned before my car had mode)
The flood was too good on the vehicle :)
& nbsp;
When making a comparison, you need to keep an eye on some variables as well "Blink" & nbsp; Although your vehicle is 1.4 75 hp, it has a weight of 800 kg. Although it is 138bg for that vehicle, 1500kg as well. I expect it to reach 200 again, though, of course
08.05.2020 16:12 # 20
34sea45
You are right in that regard, it is necessary to take into account the brother model or something + km in the
I think that when the cars go at constant speeds for a long time, I think that their engines are deaf once a week.
Page : / 3
