speakers exchange
08.05.2020 16:56 # 1
muratozhal
I have a 206 2005 model x-desing tool. If I dismantle the floors, can I install the columns that I have bought back columns? Can you make me do it or is there any wound to go to the master?
08.05.2020 16:56 # 2
Of course you can wear it.
08.05.2020 16:56 # 3
Alicilik
posterior columns are 13cm. Unless the depth is very high, you can fit all 13cm speakers. If you have an existing incoming line and original speaker, the rest is easy if you take the cable ends that will be on the head of the speaker you buy from any electrician. 15-20-25 torque wrench - star tornovida - a flat tornovida and sidebreak (to cut the socket of the current speaker connection) is enough to remove the door trim.
I am also tomorrow infinity 6530s vibe black air 6 I will replace it with.
08.05.2020 16:56 # 4
muratozhal
thank you, come easy :)
08.05.2020 16:56 # 5
serkan206
If it is a socket connection instead of 2 wires, it can be a little tired
08.05.2020 16:56 # 6
muratozhal
I do not know how to remove the floor alone, I tried today, I had trouble, so I could not go too far, can you help me?
08.05.2020 16:56 # 7
Alicilik
First you unscrew the screw inside the door handle with 20 torque wrenches. You slowly take out the handle. If it is a glass sleeve, pull it out (you can push it a little bit) to remove it. Carefully remove the frame of the door opener with the help of a flat screwdriver. There is a clip where you have difficulty, you can remove it with the help of flat tornovida. Just in case, take 15-20 of that upholstery clip while passing near the service.
If your door loudspeaker is original (there were no speakers on my back) it will be plugged in. First, remove the loudspeaker (most likely with a 20 torque wrench) then remove the socket. No need to cut the socket. Fasten aside with electrical tape and open a little from the cable part and connect the cable tightly with electrical tape.
08.05.2020 16:56 # 8
serkan206
perfect explanation & nbsp; & nbsp; "Clap"
08.05.2020 16:56 # 9
Alicilik
[QUOTE = serkan206] has been a great explanation & nbsp; & nbsp; "Clap" [/ QUOTE]
I almost unscrew once a week: D I just started to change the front teams yesterday.
Infinity 6530 is in the front and 5030 in the back. Now I bought Vibe blackair 6 in front of them. Even the driver's door alone suppressed the sound. It will be a legendary voice when it is attached to the left, but now the vehicle wants isolation. Reviews
08.05.2020 16:56 # 10
muratozhal
thank you you have been really descriptive
