speaker-sound system
08.05.2020 20:24 # 1
siyah307
good luck to all. When I turn on the original radio of my 307 model car, it sounds as if it was not pulling badly, the song playing on the radio etc. is not well understood. I am thinking of buying double din in my car, but if the sound will be bad, I will not be able to use it. I read a few things because the original radio is not very good, I wonder if my problem is to disassemble the radio and pass double religion, or is the problem arising from the speakers?
08.05.2020 20:24 # 2
onlycihan
If there is a cd aux or usb, the music played here better indicates the condition of the speaker.
08.05.2020 20:24 # 3
siyah307
unfortunately they don't. I guess I can try with the apparatus from the cigarette lighter entrance
08.05.2020 20:24 # 4
erdalaktay
I CAN'T PLAY VIDEO IN 2017 MODEL 208 FOR MY FRIENDS HOW CAN I SOLVE IT?
EMERGENCY SOLUTION PLEASE ...
08.05.2020 20:24 # 5
maximusti
unfortunately the original tapes and speakers are very bad.
There are 250 to 300 tly beautiful pioneer tapes, you can buy them and get around 100tl better speakers than the original in 1 set.
or tape amp 4 column trilogy. if you start with something low level it will cost around 1000 TL. but it has no end ..
08.05.2020 20:24 # 6
OguzhanKucuk61
There is a vendor named İsmail berke from the owner. It prepares and sells the complete set. Prices start from 450-500. In the amplifier speakers subwoofer cable puts everything, except tape. Are these taken?
How does this set at such a low price? I wonder if he is collecting deep goods? Do you have information ?
08.05.2020 20:24 # 7
OguzhanKucuk61
Example ad link
JBL Roadstar Pionner made a set in this ad.
I have nothing to do with the seller. I'm asking as a user.
08.05.2020 20:24 # 8
maximusti
My advice is never, but don't trust a salesman.
Search the internet, get everything in pieces.
If you are thinking of the amplifier subwoofer, buy 5 channels, if you don't think 4 channels, Sony, cadence, xetec, qline, rocford. The most important elements are electrical installations and amplifiers.
Then look at the amp speakers. I recommend zeroing the speakers because they might be tired or despised.
Choose electrical cables from 100% copper cables.
Keep the rms values of the amp and the hoperlors close to each other in the range of + -10 rms.
I do not recommend brands like roadstar, piranha, jameason, goldmaster.
My system (setup is not finished yet)
Cadence t5.90 amp
Forx 16cm midrange
Infinity 9633i ovals
Pioneer ts-s20 Tweeter
Xetec 1200w 30 cm subwoofer
Qline 2 awg cable.
Tesla 200A fuse and box
18awg speaker cable
4x cadence gold rca set.
08.05.2020 20:24 # 9
OguzhanKucuk61
Thank you it has been a useful sharing. Unfortunately, I do not know much about the brand model. I was wearing a Roadstar tape recorder when I first bought it. I thought Pionner was good as a by-product. But it's mediocre.
Well, if I never got into the subwoofer business.
4 door loudspeakers, an amp to feed them, and a nice new tape, how much does it cost me?
08.05.2020 20:24 # 10
maximusti
Buy the Sony Xm-N1004 amplifier, you can find 200 tlye used, zero around 350.
1 set pioneer oval in a row, around 150 200 rubles
midrange to the front doors, around 250 to 300.
For ovals, you will get a pandisot, about 100 TL.
keeps a minimum of 150 - 200 TL in cables.
if you get the plumber installed, they will charge around 100 TL.
and if you are going to install it on the original tape deck converter 50 60 TL.
it is a costly and hard work.
08.05.2020 20:24 # 11
siyah307
kits installed from the cigarette lighter input then will not affect the sound quality.
08.05.2020 20:24 # 12
pusutr
If you do not have an idea about systems, you can browse the systems of ismail berkenin. I shop from them. I was satisfied with the style of communication.
I think you can trust the systems that İsmail berke has set up.
And I think if it is listening to music, I recommend you to look at high-end systems. If the goal is sound, you can get it from the cheapest systems.
Regarding the price, you can still make your purchase in this way by researching and considering the reliability of the company.
Stay away from going :)
08.05.2020 20:24 # 13
OguzhanKucuk61
[QUOTE = pusutr] If you do not have an idea about systems, you can browse the systems of ismail berkenin. I shop from them. I was satisfied with the style of communication.
Thanks. Of course I wanted to listen to quality music. But if the budget is enough :) I do not have to worry about playing the piece playing
08.05.2020 20:24 # 14
OguzhanKucuk61
[QUOTE = maximusti] Get the Sony Xm-N1004 amp, you can find used 200 tlye, zero around 350.
It seems that it touches the tooth down from 1000 lira, it is not possible to arrange anything. I know that in audio systems, quality does not end, there is always better. But I thought the start would be less than 1000 lira If I pack up, I'll have a tube installed. Guess the system next job
08.05.2020 20:24 # 15
ggitaristt
You can get at least 200 pounds pioneer sony kenwood or worst jvc or something .. Or a nice double tape but the good ones are expensive ..
Under 100 lira, get 17cm to the front doors and 13cm to the back.
It starts its job for the beginning .. Anfi and bass next works ..
08.05.2020 20:24 # 16
maximusti
[QUOTE = oguzhankucuk61]
It seems that it touches the tooth down from 1000 lira, it is not possible to arrange anything. I know that in audio systems, quality does not end, there is always better. But I thought the start would be less than 1000 lira If I pack up, I'll have a tube installed. Guess the system next job [/ QUOTE]
As Pusutr said, the prices of ismail berk are generally more affordable than other stores. but some parts are more expensive.
You can take it from there, piece by piece, 1000 tl below, but it is not worth it.
I bought one piece of gold every month, so I feel comfortable if you do it at least.
but it is very difficult for you to decide what to buy before buying.
I also throw a ready set 500 TL but they do not end 500 TL.
even those who want 50 TL for tuning the amp :)
08.05.2020 20:24 # 17
OguzhanKucuk61
[QUOTE = ggitaristt] You can get pioneer sony kenwood or the worst jvc or something at least 200 lira .. Or a nice double tape but the good ones are expensive ..
I think I will do so. Because I can't just get everything together. And whatever I get, I'll get better sound than the current one. We need to start with something that is forward-looking.
08.05.2020 20:24 # 18
OguzhanKucuk61
[QUOTE = maximusti] [QUOTE = OguzhanKucuk61]
When you do not understand the job very correctly, it will be 50 or 100.
To start, I want to open with a nice tape and speaker for 4 doors, as @ggitaristt said. But when I want to run away and improve, I don't want to renew it again.
The advice I want from you,
1. A tape recommendation with sd, aux, usb and absolutely bluetooth. (It would be just one of sd or usb)
2. A speaker recommendation for 4 doors where I can get quality sound. (I know there are 2 kinds of components and coaxial.
3. I want it to be suitable for this speakers as I will support an amplifier in the future.
4. I also think of the subwoofer and the mono amp to feed it. Of course later.
If the door speakers can give the bass and stomachs at a sufficient level with amp support, it will be without the subwoofer. I think the component coaxial difference comes in here.
It would be better if the pendulum is not an oval condition. I don't want to cut it and I don't like its appearance. But if necessary, we will do what is necessary :)
There is also a tweeter from the original. Inside the rearview mirrors. Its quality is controversial, but I can also get a couple of tweeters if necessary.
These are what I want. If I have mistakes, correct them. I expect help from people who know the job like you. Sorry it's long, thanks :)
08.05.2020 20:24 # 19
ggitaristt
@ OguzhanKucuk61 I said buy cheap on the doors because 25 30w rms speakers are not expensive and only for tape .. No, I will use a good component (i.e. the crossover device, the tweeters and the speakers separately). In other words, 4 speakers, 4 tweeters 500 liras.
Oval pioneer speakers deliver high and high quality sound (after all, compared to others) and do not fit any car as standard.
The tip of this work is very clear .. But you can not get the sound of the box press with other speakers ..
08.05.2020 20:24 # 20
ggitaristt
http://urun.gittigidiyor.com/otomobil-motor-aksesuar/pioneer-2017-model-mvh-08-4-x-50-watt-oto-teyp-usb-280237158?mkwid=s2r67z7ın_dc&pcrid=58375872447&pkw=&pmt= & ggmktg = paidsearch * PLA * 232252887 * 22324021047 * 58375872447 * ** pla-pla = 58375872447 & 79002696327 & rFC-pkfu3g_yncw01mtsrocvojw_wcb & gclid = cjwkeajw4ıjkbrdr6p752ccum3ksjac-eqrts0ekrsgunleo3rkbsyip4mb8 ads & scxid mpch = = 14489-145818-2357-0
Usb player, fast, one of the strongest output tapes, beautiful equalizer setting, meets the daily need of use, you can control the amp .. You can say that it will be `` let it go over it '' while selling the car ..
Page : / 2
