Speaker etc. Help. Especially herry teacher
08.05.2020 19:35 # 1
Barut
I have a Goldmaster 1600 amp and cadence box bass, pioneer tape in my car, my rear speakers are broken. When I bought it, I say I change the speakers in the front doors. So I want a speaker recommendation :) I have one more question, if I put 2 speakers in the luggage pandizot will it be removed? Herry master, especially I ask you because I don't understand from these works, I bought the vehicle in this way.
08.05.2020 19:35 # 2
mimit
Do you know the amp model or the number of outputs? I guess so, one of the 4-channel power amplifiers, and they fed the bass by bridging it, so two channels went from the head, two channels left in the pandizos, and if you feed them from the amp, this time in the vehicle acoustic name. There is nothing left behind the sound intensely, if you feed the front components from the outputs of the amp and use them for the ovals on the tape and make a nice adjustment on both the tape and the amp, it may be possible to get a smoother and balanced sound, but it is basically unreasonable to feed the bass with the stereo amp. .
Evaluating the amplifier in your hand and switching to a 5-channel amplifier will be an on-the-spot movement to establish a healthier system, jbl 5355 or xetec 172.5 can be used, xetec is higher in power but there is a heat problem. In power, sound is not muted with compatible devices, the bass output stops sound after a while, repairing the soldering of the output, after a long time runs smoothly.
I could not recommend the speaker because the device does not have power information.
08.05.2020 19:35 # 3
Barut
Do you know the [QUOTE = mimit] amp model or the number of outputs, I guess it is one of the 4-channel power amplified amplifiers, and they fed the bass by bridging it, so two channels from the head are gone, if you put two ovals in the two-channel pendulum, and feed them from the amp, This time, there is nothing left in the vehicle for the acoustic name, the sound comes from behind, if you feed the front components from the outputs of the amplifier and use it for ovals in the tape and if a nice adjustment is made on both the tape and the amp, it may be possible to get a more smooth and balanced sound, but the bass with the stereo amp. fostering is already irrational at its core.
I could not recommend the speaker because the device does not have power information. [/ QUOTE] First of all thank you for the answer, master. Anfi goldmaster anf 987 should be 4x400 on it. Actually, I do not understand at all about these works :) The speakers in the rear doors break out only if I change them.
08.05.2020 19:35 # 4
mimit
I looked at the amp, as I guess, I don't know what the back door dimensions are, but if it is going to be connected without an amp, I recommend you to buy two-way coaxials since jbl and pioneer has a lot of flashes. According to the size of the rear speaker, suitable size can be chosen from the Alpine SXE series or Sony XS-GT series.
If you tell me to use the empty outputs of the amp, it is necessary to use the component whether it is front or back, the pandizota is oval, but there is no acoustic inside the vehicle, I think it would be uncomfortable. As a component, suitable way vibe slick series or lower level products of powerbass can be preferred.
My personal recommendation is to update the system gradually, using a 5 channel amp and two sets of components, and the existing bass to get a better quality, clearer sound.
08.05.2020 19:35 # 5
Barut
[QUOTE = mimit] I looked at the amplifier, as I guess, I do not know what the back door dimensions are, but if it is to be connected without an amp, I recommend you to buy two-way coaxials since jbl and pioneer has a lot of flashes. According to the size of the rear speaker, suitable size can be chosen from the Alpine SXE series or Sony XS-GT series.
[/ QUOTE] Got it, thank you very much, master
08.05.2020 19:35 # 6
herry
First of all, thank you for your invitation, I believe that I have more knowledgeable friends than me, even the friend who wrote on the beach is very nice, my humble advice is to start with a 5-channel quality amp, you will complete the rest in time. your bass box already exists it will appear.
08.05.2020 19:35 # 7
Barut
[QUOTE = herry] teacher, thank you for your invitation first, I believe that I have more knowledgeable friends than me, even my friend who wrote about the place is very beautiful, my humble advice will start with a 5-channel quality amp, you will complete the rest in time. your bass box already exists it will appear.
[/ QUOTE] Thank you my brother for your attention. Essentially, the sound in the vehicle is enough for me, since the rear door speaker is broken, I cut their voices only the front door speakers and bass are working, my main purpose is to change the rear door speaker, if I do not wear a speaker in the panzido. I don't want to spend a lot of money on this because I have no curiosity and interest in my head. I just need to change the rear door speakers for me.
08.05.2020 19:35 # 8
mimit
Do not just look at it as loud sound, quality music makes long journeys more enjoyable, it also cheers people in the city especially in congested traffic, it is a very open sector, but with the right devices and a good setting, good results can be obtained at an affordable price. It's all about enjoying, listening to music, not noise :)
08.05.2020 19:35 # 9
Barut
[QUOTE = mimit] Don't just look at it as loud, quality music makes long journeys more enjoyable, it also cheers people in the city especially in congested traffic, it is a very open sector, but with the right devices and a good setting, good results can also be obtained. . It is all about enjoyment, listening to music, not noise. Maybe I will do something good in the future, but now my priority is the car's spring, etc. If you just recommend me a speaker, I say I will insulate the doors and change the speaker when I remove it. 13 cm rear door speakers.
08.05.2020 19:35 # 10
mimit
If you say it is affordable, you can also look at the alpine sxe series, there are pioneer tsg 132CI models, this system resembles components as bass and treble can be used in separate places, but a normal speaker can actually be a more affordable normal pioneer tsg 1332i.
alpine spg13c2 or hertz dcx series will be the 13th even if you can increase the budget a little more. There were a lot of options but I would recommend you to buy one of these products and if possible, listen and buy, each brand and model offers different tones according to the material and structure used. The treble of the alpine is softer, for example compared to pioneer.
08.05.2020 19:35 # 11
Barut
[QUOTE = mimit] If you want to be affordable, you can also look at the alpine sxe series, there are pioneer tsg 132CI models, this system resembles components as bass and treble can be used in separate places, but a normal speaker can actually be a more affordable normal pioneer tsg 1332i.
[/ QUOTE] Let me take a look at these products, thank you again for your interest.
08.05.2020 19:35 # 12
okan77
Thank you very much for your sharing ... something has come to my head for my vehicle ...
08.05.2020 19:35 # 13
Mesut48
God bless the writers, it worked for me very much, I will start with the tape :)
08.05.2020 19:35 # 14
Barut
My friends aim is not only me, but everyone can benefit, we know more about each other here because I could get some special ideas from our brothers Herry and Mimit, but thanks to this, most people benefited, this is the purpose of the forum.
