Speaker |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Peugeot Sound Systems | |
| 08.05.2020 20:47 | # 1 |
| 08.05.2020 20:47 | # 2 |
sonerkyl |
You have to replace my professor.
| 08.05.2020 20:47 | # 3 |
They're not broken, I put on another speaker, the room didn't work, it doesn't come electric
| 08.05.2020 20:47 | # 4 |
maximusti |
Just try to give the sound back in the tape settings, is it working or not? If there is no front-back adjustment among the options, it is not active on the tape.
| 08.05.2020 20:47 | # 5 |
I tried it but only the balance adjustment is turned to the right and left, there is no adjustment to the rear speaker.
| 08.05.2020 20:47 | # 6 |
maximusti |
[QUOTE = Mehmet UYAR] I tried it but only the balance balance is right and left, the back speaker is not set. If the tape is not active, do I need to connect it to the computer [/ QUOTE] In the 206's, the rear door speakers are not active, this is probably the case with tenths, Diagbox etc. from the computer. can be opened with a similar program. You can get it done by a service or auto electrician.
| 08.05.2020 20:47 | # 7 |
The tape is corrected by adjusting from the fader section. If the fader feature is not available on the tape, the fader feature should be activated by connecting with the device.
