Spark plug socket
08.05.2020 14:18 # 1
Hello again,
& nbsp;
I want to replace the spark plugs myself. I found the necessary documents on how to reach the spark plugs and downloaded them. I will get spark plugs (4) from the authorized service for 40 ytl. But I think I will need the spark plug socket to replace them. Can I buy this loaf individually or do I have to buy the bite set? There is also an extension of this. Where can I buy these two? & Nbsp; & nbsp; And, is spark plug standard? So there is a certain size, criterion & nbsp; of the spark plug socket we will buy to replace the spark plugs of the vehicle? I am asking because I am writing from abroad but my father who will do this is "Embarrassed" & nbsp; Will I need another tool?
& nbsp;. It says 21mm (13/16) SP SOCKET on it. Does this bite see my name? & Nbsp;
& nbsp;
Thanks. 1.6 petrol.
koliva 2010-07-10 11:14:52
08.05.2020 14:18 # 2
turbo27
spark plug sockets are used as 16 and 21 mm ... sold one by one. Do not mix the wires.
08.05.2020 14:18 # 3
Melih
hello it is best to take my personal opinion to the master and have it replaced, my master said that the spark plugs will consume excess fuel if the air gets loose and the teeth will corrode and wrap when disassembling.
08.05.2020 14:18 # 4
[QUOTE = turbo27] spark plug sockets are used as 16 and 21 mm ... sold individually. Do not mix the wires. / DIV>
& nbsp;
How do I know if my vehicle is 16 or 21? 21mm (13/16) SP SOCKET is written on the bite in me. Which is suitable for this? Is it suitable? I will show maximum attention not to confuse their rank. and over time he said that the teeth would corrode and wrap while removing. [/ QUOTE]
I trust myself. Besides, even if it will be the worst case, I will still do it. My goal is to learn. Even if the vehicle is scrapped, it's okay.
08.05.2020 14:18 # 5
turbo27
16lık & nbsp; & nbsp; I say again do not interfere ....
08.05.2020 14:18 # 6
[QUOTE = turbo27] 16lık & nbsp; & nbsp; I say again, do not mix .... [/ QUOTE]
& nbsp;
So this is not my case. We'll have to get it too.
I will put labels showing the top order of all of them without removing the wires. I will do this estimated work next week. Until then, I already read a document. Thank you very much.
08.05.2020 14:18 # 7
turbo27
No need to put a label, just plug and unplug one by one like a spark plug change, it will not mix anytime, plug the cable, loosen the plug, then plug the new spark plug in a way that it will not catch the teeth first, but hold it out with your hand, then it will not tighten the standard, but it will not tighten but it will be solid. . Plug in the cable again ... that's all, you don't need the document ... easy to come.
08.05.2020 14:18 # 8
[QUOTE = turbo27] There is no need to put a label, just plug and unplug one by one, do not interfere one by one, loose the plug, loosen the cable, the new spark plug will not catch the teeth first, hold it out with your hand, then tighten the standard spark plug ... but firmly tight. plug in the cable again ... that's all, you don't need the document ... let it be easy now .. [/ QUOTE]
08.05.2020 14:18 # 9
peugeotefe
No spark plug wiring at 307, direct electronic ignition, so it will be easier for you to change the spark plug. 2. After unscrewing the 6 bolts, you remove the 5 bolts of the coil with a 20 torque screwdriver, then remove the socket of the coil and set it aside, then unscrew it with 16 long socket-long arm-T arm. This much. Come Easy
peugeotefe 2010-07-10 17:39:30
