Spark plug replacement for 206 (with picture)
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 15:53 # 1
mon
We first supply a 16mm "spark plug" wrench from a hardware store as follows. 10 liras
On the motor, we remove the energy cable of the distribitor in the picture, the motor ventilation pipe and the two right and left nuts with 10 socket.
Uploaded with ImageShack.us
Be careful that there are springs in the disassembled part so that it does not fall.
Then we start removing the spark plugs with our spark plug wrench. Let's be careful at this point.
The old spark plugs' nail distance has increased considerably. It's time to change.
these are our new spark plugs. kit 25 tl number RFC58LZK
nail distance is pretty good.
we collect it in the same order again. The prescribed tightening force is 28 Nm.
mo 2011-07-23 11:07:52
08.05.2020 15:53 # 2
Thank you for this beautiful work.
Maybe it would be more comprehensive if you change the title to "Replacing spark plug for 206". Other vehicles have minor changes in the upper part.
08.05.2020 15:53 # 3
metin
Mon is good for your hands. I didn't know the spark plug wrench was so suitable. so I changed it to the master. I would buy it myself. I wonder how you did tightening at 25 nm.
08.05.2020 15:53 # 4
mon
[QUOTE = text] Mon's hands are very good health. I didn't know the spark plug wrench was so suitable. so I changed it to the master. I would buy it myself. I wonder how you made the tightening at 25 nm force. [/ QUOTE]
Well, it says 25Nm in the spark plug box, but we don't have a torque meter. I read it somewhere, saying it was tighten 30 degrees more after it got completely empty. I applied it. :)
08.05.2020 15:53 # 5
metin
If I have a way to industry, I will buy one too.
08.05.2020 15:53 # 6
mon
If you can, take one and set it aside. If you go to the master, you will want at least 10 TL of labor
08.05.2020 15:53 # 7
g-demir
+1 Thumbs Up
08.05.2020 15:53 # 8
Your expression of health is beautiful. But if you do not understand wrong, I want to say my point at this point.
I think replacing the spark plug is not a heat anyone can do. Even if it seems very simple, the slightest mistake can cause a lot of expenses. Also, you cannot insert a spark plug that has been firmly tightened with the tool you have shown. Moment size is not enough. I just inserted my spark plug with a ratchet sleeve. In the meantime, after the mistakes such as breaking the spark plug or snapping it out, great problems can arise. There may be problems with inserting hoses or inserting the bobbin. When I say let me make a profit of 20 TL, it can be damaged at 200 TL. Gülme
As a result, it is very easy to do by sensitive and conscious hands. However, it is dangerous for those who do not have much skill to try to do it. It is recommended to give a maximum of 20 TL and change it to a master ...
08.05.2020 15:53 # 9
mon
I said to the friend if he was already able to. Of course, it would be wrong for someone who does not know to replace the spark plug. But if at least he knows a few things, I highly recommend replacing ce. Because "Curiosity is the door of knowledge".
08.05.2020 15:53 # 10
tigerland
good job. health to your hands.
08.05.2020 15:53 # 11
I want to do it myself, but I think I can? It doesn't look like a skillful job, but I don't know. Geek
08.05.2020 15:53 # 12
[QUOTE = hLL 206] I want to do it myself, but I think I can? It doesn't look like a skillful job, but I don't know. Geek [/ QUOTE]
You do, why not. Even i do it myself Smile
08.05.2020 15:53 # 13
alihan59
Couldn't you update the photos?
