Spark plug replacement
08.05.2020 14:51 # 1
Hello,
On the days we went, I asked some questions about changing spark plugs in the forum. I would like to replace the spark plugs of my 2003 model gasoline 307 SW 1.6.
Original spark plugs are in my hands today. I removed the engine top cover by inserting the 6 wedding ring screws. I thought I would encounter direct spark plugs and cables connected to them, but I encountered a landscape that I never expected. I wanted to ask you expert friends again to avoid doing wrong things.
In the photos below, you can see the view I met. Especially in the second photo, the metal hose goes into the places where I take the red circle. Is there liquid or air in it? Yellow parts can be printed. I think I can press it and pull it off. Is it true? If Mumkun can you say, do it like this in the photos? There is also something like an electrical socket on the part of the blue circle. Should I pull him out?
1: Unopened form of the engine cover.
2: After opening the engine cover.
3. Another pain.
Thank you so much.
Koliva 2010-07-16 20:27:59
08.05.2020 14:51 # 2
hasimayaz
First picture:
1-2: Press the yellow buttons to remove the steam fittings.
3-4-5-6: Remove 4 torque screws
7: Disconnect the electrical connection by pressing the wire lock on the top. If you want, you can continue taking it aside without disassembling.
Second Image:
Take out the coil box 1 and extensions 2. replace your spark plugs with new ones. reverse it all, following the order.
08.05.2020 14:51 # 3
Thank you very much indeed, you provided very descriptive and very informative information. Tomorrow morning the first name is to do this. I didn't write anyway here :) Good night.
08.05.2020 14:51 # 4
Hello again,
This morning I successfully replaced the spark plugs. The first spark plug is really tight. I had a little difficulty getting out. I sweated a lot because of the fear, but in the end everything went well and changed. After a couple of weeks, I will check if I could tighten the spark plugs again. Below is the condition of the spark plugs I have removed. Is it possible to make a comment about the engine by looking at them? Do you think everything is fine?
08.05.2020 14:51 # 5
karayel1984
what a nice subject pictures fln, spark plug change came =)
08.05.2020 14:51 # 6
okankrgz
dear beaaa :)
