Spark plug, filter, lining recommendations
08.05.2020 17:51 # 1
ByKaos
For 120 thousand maintenance, I think of changing the oil, air pollen gasoline filters, spark plugs, brake pads, oil. Which oil do you recommend as an oil? Do you recommend a spark plug for performance or a standard spark plug? Would you recommend ceramic pads or normal pads as a pad? Are there any other parts of my vehicle that you would suggest to change? Is the buffer of the 206 GTI the 206 xt me (:
08.05.2020 17:51 # 2
The filter does not change, I recommend you to use the original in others. If the oil is preferable from brands such as castrol, mobile, I ask the master to ask for the balata, maybe it does not need to be changed. It is useful for you to know what you bought yourself.
08.05.2020 17:51 # 3
In addition, as far as I understand, you are using the vehicle in a combative manner.120 thousand means heavy maintenance.
08.05.2020 17:51 # 4
ByKaos
triger has changed 5 thousand km ago, I showed it to the master, he said it changed, but I can not trust the masters here. (: these oils have 10w40 style stuff, or what number are used in them?
Footnote: I am using some pretty combative: /
08.05.2020 17:51 # 5
It takes 10-40 jobs.
08.05.2020 17:51 # 6
ByKaos
Meanwhile, as far as I understand the situation of mine, the car got up on the flat road in 5th gear: D I am entrusted to God. Today I traveled for 120 km, 60 departures 60 arrivals, departures 90-110 turns 130-160 once forced 180 saw (it was a little downhill but no kidding: D) I came home I have a few tests for these press pads, I looked at them, I said By Allah I have helped: /
