Spark plug failure symptoms
08.05.2020 19:12 # 1
yasin26
One of the spark plugs on my 206 vehicle would go on until the engine was on.
If your spark plug is burnt:
late work in the vehicle
your car's normal speed up to 90-110 and then knocked, the sound of the engine does not change
when you squeeze the temperature rises
decline of vehicle traction
1.2.3 does not feel anything in the gears because the compression ratio is not too much. The vehicle starts to not make the compressor in 4 5 gear. When it is idle, it sees the end of the cycle.
08.05.2020 19:12 # 2
koray.turan
[QUOTE = yasin26] One of the spark plugs on my 206 vehicle would go on until the engine was turned on.
Thanks for the information Is there a sign Bi
08.05.2020 19:12 # 3
yasin26
there is absolutely no problem in bottom gas delivery
no fluctuation in idling, no navigation
even the problem is not clear in 1 2 3 gears 4 5 gears increase in compression, then it becomes clear that the first thing that comes to mind is that the engine fills the time, so it comes to mind that it does not compress and it is called direct rectitude, so I discussed with the masters 130000 km I said before it was like a monster, dead engine I always say that unless you do something deliberate, the 2000 km engine will not die suddenly. the vehicle sees the speed of 190 km when the vehicle is changed and the temperature is not exceeding 90 ° :)
08.05.2020 19:12 # 4
yasin26
picture of spark plugs on the far left
08.05.2020 19:12 # 5
koray.turan
Get well soon bro. When I was idling, I said to myself, if the car engine feels like it is in the zipliyo site, it is even happening every 3 or 5 seconds. the koray.tur 2015-04-03 19:07:22
08.05.2020 19:12 # 6
yasin26
If there is a drop in speed during jumping,
08.05.2020 19:12 # 7
koray.turan
No drop in rotation, idling, only tachometer, no constant movement and fluctuation
