Space in the front wheels
08.05.2020 21:06 # 1
x571
Hi
When we try to turn the front wheels while on the jack, the tire turns a little and then it looks as if it is stuck as if it hit something. It was interesting that I had never paid attention before.
08.05.2020 21:06 # 2
ismailkaya
hits exactly as plug.
If you hear that sound while going normal, it means there is trouble in the axles.
When you turn the wheel while it is hanging, it gets stuck. Because the angle of the axle shaft is broken, it usually supports the swing when it is needed. I know this way. If you are in doubt, I would say to look at a good axer.
08.05.2020 21:06 # 3
x571
[QUOTE = ismailkaya] hits exactly like a plug.
No, there is no sound when it is going, just when it is on the jack.
08.05.2020 21:06 # 4
GokhaN
I don't think there is a normal problem because it is idle
