Source of water under the mat?
08.05.2020 14:56 # 1
Hello friends,
My vehicle 307 triptonic 2004 model tecnoplus is two, when I go to auto wash, there is water under the mat. Moisture and water increase to the right side to the gear side, but there is obvious water on the floor and you can see the water when you put your hand and press. In addition, engine water is also decreasing, is it a problem with the radiator? How can we understand the radiator exactly Does our lion create a swimming pool for us Gülme What could be the reason?
Thanks.
08.05.2020 14:56 # 2
_? the cover 2010-10-30 00:13:46
08.05.2020 14:56 # 3
Is there any flow under the vehicle? In addition, if there is antifreeze in the cooling system and it is missing from the honeycomb, it smells ...
08.05.2020 14:56 # 4
Does [QUOTE = cecoli] flow under the vehicle? In addition, if there is antifreeze in the cooling system and it is missing from the comb, you smell it and you can understand it from there ... [/ QUOTE]
When you say it flows under?
and there is a great smell inside. It has a heavy disgusting smell like mold. It is also in normal time, but this smell happens especially when we turn on the air conditioner.
08.05.2020 14:56 # 5
300yedi
antifreeze is the smell of my friend that smell is from the calorie heater water
08.05.2020 14:56 # 6
be careful when you wash it, the guys open the door and flood the sills while it may be leaking water from the barrier.
08.05.2020 14:56 # 7
furkan
I think go to a body shop and look at their tires
08.05.2020 14:56 # 8
[QUOTE = kapagan] [QUOTE = cecoli] is there any flow under the vehicle? In addition, if there is antifreeze in the cooling system and it is missing from the comb, you smell it and you can understand it from there ... [/ QUOTE]
Is there any coolant flowing from the bottom of the machine to the bottom of the vehicle? or is there any oil mixing situation? Anyway, these two will be leaking from the heating core inside.
08.05.2020 14:56 # 9
My first job will be to get the water business done today. In line with your suggestions, I will first follow the honeycomb and then the door seals (tires) to the last washer in the form of a brush.
08.05.2020 14:56 # 10
fieryx
slm kapagan 206 xt 1.4 I have the same problem with me a couple of months ago, the headroom radiator was missing the water, exactly where you described it, I bought the 34 TL radiator.
08.05.2020 14:56 # 11
ali oncu
I do not think it will hold a lot too, get well soon
08.05.2020 14:56 # 12
ozaannn
the same is happening in a friend, but not constantly later, then the right mop had been under the lake, but the car did not diminish as we said, we still did not find it. Sinirli
08.05.2020 14:56 # 13
okanisilak
the same problem happened in my car, water was accumulating on the driver's side.
The radiator turned out solid, but the o-ring seals in the part where the pipes carrying hot water passed to the honeycomb were old and leaking from there. I hope the honeycomb does not have to change, you handle it with the O-ring
08.05.2020 14:56 # 14
solo206
When it was raining for 4-5 months, it was getting water from the right front door, I showed it to the masters a few times, they couldn't do it. I went to Trabzon-Peugeot Bayram last week, then they didn't have a door insulator. The order has been placed. I went and changed today. Hopefully it will no longer take water ...
08.05.2020 14:56 # 15
I have been in the industry since morning, now I became an industry maniac Embarrassed
There are 3 screws in the section where the pipes that go to the source of the water to the heating radiator pass, but mine was able to find the screws and nuts to be there after one big and two empty ones. I think it's the source. So the water comes from there. Now whatever the former owner has forgotten to install the screws :) I suppose it coincided with the good of the master.
Anyway, a 10-meter fuse was dropped on the floor while removing the plastic parts located under the steering wheel to interfere with the heater. Hoppaaa started to give birth to our BSI insurance. Anyway, the employee found the fuse.
I also asked the AUX input case that I had in mind for a long time. It is known that our CD Changer plays nanay. He said "We'll do it", it didn't take 10 minutes. Shocked I tried, it works really well. Star Now I look at cd changer with pity :)
Anyway, after coming from the industry, I said, let me get the water on the floor. I pulled the carpet washing machine, pull it out, the water will not stop. Not like it will be the last, I dismantled and distributed our floor. There is a spongy material on the bottom. I took it out and took it beautifully. I left it to dry. I will take it off and wash the material I bought in a moment. It dries on the boiler until the morning.
Thank goodness I can say I got rid of it. Hopefully the problem has been solved.
Meanwhile, they said blue and red about antifreeze. Best of all, they called red, and I had red. But if I was not mistaken when I bought the vehicle, it was blue. I think it's okay, but?
08.05.2020 14:56 # 16
bayelektronik
My teacher had the same problem in my old car, I would see a puddle on the front passenger side, and the problem was that it was getting rainwater because the pollen filter cover under the windscreen was not fully attached. Water might be entering through the windshield.
08.05.2020 14:56 # 17
kizilhakan
At the weekend and last week, I was dealing with the same problems.
First, there was water in the left hind leg, I first solved it, there are pictures on the site, you are removing the plastic part on the inside of the door. If it is open, water is flowing in directly. I pasted the isolation completely with silicone and isolated it.
This week, again, there was water under the driver's place from excessive rain.
a situation that makes you feel very uncomfortable, smells like cold.
without forgetting, there are water drain holes in the doorways and it is necessary to check whether there are blocked.
thanks.
08.05.2020 14:56 # 18
I said let me check this day. The situation is the same but there is a decrease is not the same. So there is still water under the mat. Ağlama
I said to the master, let's check it out. Let's see Ağlama
08.05.2020 14:56 # 19
When I read the problems you wrote about this, I will almost give up 307.
this is the first time I have heard of these problems. Would that be nonsense? Don't the people who make this car check them. I wish my capagan brother get well soon. I am a tecnoplus patient, but I really get cold after reading these comments. Some friends made silicone or something to stop the water, some said pollen filter. it went really strange to me.
I say get well again. By the way, did you solve this water intake capagan?
maverick sbd 2011-02-20 20:55:37
08.05.2020 14:56 # 20
[QUOTE = maverick sbd] is almost going to give up 307 when you read the problems you wrote about this.
No check. If it did not exist, there would also be a water leak in my vehicle.
So much trouble happens in every vehicle.
Page : / 3
