sounds like a pat engine
08.05.2020 16:29 # 1
turkcelik
2005 model 307 1.4 hdi 68000 km, the sound of the engine has started to be heard for the last 3-4 months. Is there a solution to this, can the injector be removed by cleaning? and how to do it. and if anyone knows why this happens and explain
08.05.2020 16:29 # 2
06OzGuR06
Sir, don't believe what the service says or how they speak like this immediately. How did they understand that they would manage it for 2 years? If the injectors are missing, the injector washers will change. It is not too expensive.
If the injectors are missing, it sounds like cuf cuf while the engine is running. editID> 2011-12-28 13:28:39
08.05.2020 16:29 # 3
turkcelik
I hear a whirring sound as a voice. this sound becomes more evident especially as you press the gas. As my fuel store, it varies between 25-30 cents per km. I always bought quality fuel, or if there was an opet or shell injector occlusion, I did not understand why it was caused.
08.05.2020 16:29 # 4
Do you have the opportunity to shoot a video of water sound?
08.05.2020 16:29 # 5
06OzGuR06
[QUOTE = koliva] Do you have the opportunity to shoot a water sound video? [/ QUOTE]
It is much better if you can shoot a detailed video exactly. "Smile" Reviews
08.05.2020 16:29 # 6
06OzGuR06
[QUOTE = turkcelik] I hear the whirring sound as sound. this sound becomes more evident especially as you press the gas. As my fuel store, it varies between 25-30 cents per km. I always bought quality fuel, or if there was an opet or shell injector occlusion, I did not understand why it was caused. [/ QUOTE]
Fuel consumption is not too high. Also, if the injector is clogged, the engine will run as if it was idling. It runs irregularly. If there are other symptoms in the vehicle, it would be better if you write them in detail. On idling and vehicle performance.
08.05.2020 16:29 # 7
yavuz25
What are the belts?
