Sounds from 307 front teams .....
08.05.2020 14:09 # 1
coyote26
recently, my friends front line of my car has a lush and full sound .... On the road that makes it more wobbly, when I get off intentionally, on some bad roads and accelerates and pulls my feet out of the gas .... I went to the industry 2 months ago to change the pad to that day. I took it and made it look at the master, they did not have any problematic parts in the front team, they said it was very good, but they did not find the source of the sound. I did not have much time. Why do you think this is caused by the sound?
08.05.2020 14:09 # 2
coyote26
I think there is no one who has an opinion on this issue.
08.05.2020 14:09 # 3
I also have 307, I think the same sound, I also figured it out.
08.05.2020 14:09 # 4
Rfk
Is there a spring in the vehicle?
08.05.2020 14:09 # 5
coyote26
ewt there is a bow on the vehicle ... 2-3 days ago I got to the master, he was a master of the pejo .... There is no problem in the ten teams of the vehicle that the master called me. He said come back .... this was the 4th master who said there was no problem in the ten teams .... The springs I used in my vehicle FK 3.5cm
Can I get your opinions on this matter?
08.05.2020 14:09 # 6
coyote26
[QUOTE = yamyam307] i also have 307 same sound i guess i also solved it in me. Echo sounds echo.
Unfortunately, I was in Eskişehir. If I was there, I would have heard the sound.
08.05.2020 14:09 # 7
pug307_26
one of the probable springs my fellow, who is the master you call peugeot crew,
08.05.2020 14:09 # 8
okan77
I advise you to look at the rod and tie rods ... it was knocking, I changed it too, believe me, driving pleasure peaked ...
08.05.2020 14:09 # 9
okan77
my hee vehicle is 307 xt by the way ...
08.05.2020 14:09 # 10
coyote26
[QUOTE = pug307_26] is one of the possible springs my fellow, who is the master you call peugeot man, you need to be able to recommend such a master [/ QUOTE]
I guess let's look at the bows
KAREL OTO Robust land
This address is a very good master who helps me describe my car as a reference.
http://www.servisnerede.com/servis/%c3%b6zel-servis/464/peugeot--eski%c5%9fehir-karel-oto.html
08.05.2020 14:09 # 11
coyote26
[QUOTE = okan77] I advise you to look at the rod and rod rods ... it was knock, knocked, I changed it too, believe driving pleasure peaked ... [/ QUOTE]
Rot, rot heads Z rot was all looked at from them .....
08.05.2020 14:09 # 12
neo
The springs I put in my old car audi were also making sound. She got out of the package with a hose. but we had to put the spring before the hose passed. From where to time. we put the hose, the sound was cut off !!! :) If your springs came with a hose and you didn't wear it, you made a mistake.
08.05.2020 14:09 # 13
vbmaster
sports springs are sold with hoses anyway. am I wrong? Is there a single spring box.
08.05.2020 14:09 # 14
coyote26
Walla me, FK hot springs did not come out of the box, so we put it in. The master says it comes from the springs, but does it make a sound even in the slightest yawn?
08.05.2020 14:09 # 15
the_beKKo
[QUOTE = coyote26] walla myself did not come out of the box of the FK bows, so we put it in the way. The master says it comes from the bows, but do I make a sound even in the slightest yawn? [/ QUOTE]
i think he is doing Dil Çıkarma In our 307 fk, after the vehicle is off the lift, we make a heavy blow on each left, and spray a spray on the left side. Gülme
08.05.2020 14:09 # 16
coyote26
[QUOTE = the_beKKo] [QUOTE = coyote26] walla me did not come out of the box of the FK springs so we put it in the way. The master says it comes from the springs but do I make sound even in the slightest yawn? [/ QUOTE]
I will change the springs if the problem is definitely caused by the springs, but I can not be sure.
08.05.2020 14:09 # 17
selcuk-307
[QUOTE = coyote26] [QUOTE = the_beKKo] [QUOTE = coyote26] walla me, I have not gotten out of the FK bows box. [/ QUOTE]
I think there is no problem with hose pass springs. If there is no hose, it will sound even in the slightest stretching. As a result, there are 1300 kilos of big cars on 4 broadcasts.
08.05.2020 14:09 # 18
coyote26
[QUOTE = selcuk-307] [QUOTE = coyote26] [QUOTE = the_beKKo] [QUOTE = coyote26] walla me, I don't get hot from the box of the FK bows. [/ QUOTE]
Thank you ... my springs because I just got zero zero .... I have been using the springs for 4-5 months .... I have only one question. disassembled complete springs?
