Sounds from 307 front layouts!
08.05.2020 18:51 # 1
Orcun.Dmr
The sound of 307min is coming from the front layout, the problem of clicker felt when I entered the broken road but it was an expensive thing in that piece. I have one more question, when I get 140 km, my car starts to shake a lot and they said I need to install steel cant. What could be the problem. Thanks for your help in advance.
08.05.2020 18:51 # 2
Orcun.Dmr
Guys, does anyone know what the problem is?
08.05.2020 18:51 # 3
hatayli
If you make a sound when you enter the pits when you say the front layout, have the rot heads and the z rods checked. these can make sound
08.05.2020 18:51 # 4
hatayli
it may also make the tremor imbalance in the balance setting. I would like to check the balance setting.
08.05.2020 18:51 # 5
samet206
They said that I need to put on my steel rim, I don't understand what kind of advice is a special case, whether you are wearing steel or hair rim is nothing but visual. Also, the front set can be swivel heads, balance arms or something, look at them. For this reason, it may cause problems for you. The tremor situation is probably due to this. If the wheels are so crooked, they may have told you to change the wheels.
08.05.2020 18:51 # 6
Gokhan_35
samet the same problem was still in me, my car is trembling at a certain speed, I have a very strong rotbalanç, we experimented with it, solved it in 5 minutes and got rid of it, there was a problem in the axles, try it yourself without dealing with other things.
08.05.2020 18:51 # 7
samet206
[QUOTE = Gökhan_35] samet the same problem was still on me, my car is shaking at a certain speed, I have a very robust rotbalanç, we had experience with it in 5 minutes and it got rid of it, I had trouble in the axles, try it yourself without dealing with other things. at least you won't lose anything .. [/ QUOTE]
I agree that you can do that from the axles, there is a possibility, but when you do it from the axle, the front team does not sound, knocks or something makes the car tremble, does not give any noise on the bad road, so I did not write it. but that's right at this possibility.
08.05.2020 18:51 # 8
Orcun.Dmr
Thanks for your answers, the problem of friends has been solved.
