Sounds from 307 :))
08.05.2020 15:45 # 1
burakdmr
Hi friends .. My question is when the vehicle is driving on a bumpy road, there are voices coming from the right to the left, through the door, torpedo, etc. .. It is not serious, but squeaks that shake the person :)) Is there a solution for them ??
In my second question, when I turn the steering wheel back to the left, there is always a roaring noise, if not always causing a serious problem ??
Thanks to all of you in advance ...
08.05.2020 15:45 # 2
metin
what is your tire condition The suspension of the 307s is a bit harsh, over time, there are clicks, my tires are old and very hard, they cannot absorb the blows, they were giving in. I changed the tires, got rid of it, there is no sound anymore.
There is a constant hum of sound, no matter what the steering is, back and forth, even when it is made to the right or left, the sound is increased, while the steering pump has difficulty, so it is not recommended to break the steering wheel completely.
08.05.2020 15:45 # 3
friends, I can use the heel here instead of opening a new topic, and I have a complaint.
08.05.2020 15:45 # 4
metin
the same thing happened to me. cooling people out of the car (:
There are z rods, they are branded quickly, about 20 TL change them, the sound is cut.
If you suspect the shock absorber, it will muddle the vehicle with your hand and make a sound when it sounds "lok lok" but I wouldn't recommend it, as you know, the front fenders remain in the plastic then.
text 2011-07-04 13:52:29
08.05.2020 15:45 # 5
[QUOTE = text] the same thing happened to me. cooling people out of the car (:
Well, when I go home one evening, I have an experience without loading into the fender .... Thank you very much, my brother. Göz Kırpma
08.05.2020 15:45 # 6
metin
I am asking, brother, I said the same sound was coming from my front team. The front was going to go completely. I searched for shock absorbers or something.
I said what happened to me because your distress is the same as mine, I hope to be misled.
08.05.2020 15:45 # 7
ose
[QUOTE = text] I am asking, my brother said the same sound was coming from my front team, the front was going to go completely, I searched for shock absorbers or something, then set some money and went to the master looked.
[/ QUOTE] I agree, if you ask the authorized service, they say that the complete front team will not change.
08.05.2020 15:45 # 8
burakdmr
Either it does not come from under my voices, or more squeaky creaking like that, squeaking from the console through the back door flan :)
08.05.2020 15:45 # 9
metin
[QUOTE = basistrakrak] either does not come from underneath my sounds or such more squeaky squeaks from the torpedo from the console back door flan :) squeaking if it is full [/ QUOTE]
In this case, the hardness and softness of the tire is important. If the tires are old, they do not absorb impacts because they harden. tire air is important, if it is more than normal, it shocks and sounds from inside nevertheless, they recommended me a silicone spray, but I never used it, but I don't know. I think he was cutting the sound.
08.05.2020 15:45 # 10
burakdmr
Hmm, I haven't looked at the tire weather for a long time .. are you doing 32 back and 30 back
08.05.2020 15:45 # 11
metin
[QUOTE = basistrakrak] Hmm I haven't looked at the tire weather for a long time .. do you have 32 back and 30 back [/ QUOTE]
front and back 33 or front and back 34. If there is a load on the back, the back should be 1-2 psi higher.
08.05.2020 15:45 # 12
[QUOTE = basistrakrak] Hi friends .. My question is when the vehicle is going on a bumpy road, there are voices coming from the right and the inside of the door from the torpedo, etc. It is not serious, but the squeaking the people inside :) Is there a solution for them?
There is no solution .. it makes 307 sounds on rough road.
roaring is normal, you can find the reason for roaring in detail in the forum.
08.05.2020 15:45 # 13
burakdmr
[QUOTE = text] [QUOTE = basistrakrak] Hmm, I haven't looked at the tire weather for a long time .. are you doing 32 backs 30 backs [/ QUOTE]
I usually ride a maximum of 2 people, then I will make 32 or 33 best :)
We will visit with patterned squeaks, it is best to find out where it comes from. Maybe I can make an application later in the car.
08.05.2020 15:45 # 14
DRIVER34
In the morning, I started screaming from my left seat squeak ....
08.05.2020 15:45 # 15
[QUOTE = DRIVER34] In the morning my creak started to come out of my left seat .... I fell .... [/ QUOTE]
Need to check the bottom mechanism. In my opinion, if the spray is lubricated with oil ...
08.05.2020 15:45 # 16
DRIVER34
[QUOTE = CeCoLi] [QUOTE = DRIVER34] In the morning, I started to squeak from my left seat, I was scabies .... [/ QUOTE]
I guess so it was overlapping everything 2 days ago cd changer broke down cd is not playing now wedding eve is annoying things ..
08.05.2020 15:45 # 17
burakdmr
I will throw all the knick knuckles this evening, I will renew the air of the tire from the vehicle tonight, I will detect the squeaking places and glue it with an insulating tape :)
08.05.2020 15:45 # 18
metin
Usually squeaks are caused by torpedoes that harden in the sun.
Did you try care milk etc. when you park the vehicle, do you wear something on the windshield to protect it from the sun or spread it to the torpedo?
I have never had a problem since I took these measures,
08.05.2020 15:45 # 19
burakdmr
I use care milk, I am very pleased, my squeaks usually come from the doors
08.05.2020 15:45 # 20
metin
you can open the door and lubricate the parts inside it, over time it may have been loosened / worn by the vibration received by the vehicle from the road
Page : / 3
