Sounds and odors inside the vehicle
08.05.2020 14:58 # 1
nteker
My masters and friends have not completed my 2004 model LPG (Landi) Peugeout 307 1.6 XR, but I have encountered many problems. I shared many of my problems here, thanks to some friends I got some problems, first of all thanks to everyone who helped. But since I bought the car, I have spent around 1000 TL and still the problem is still the problem. Let me briefly explain what I have done with 1000TL, and for a few problems that are still ongoing, please help me now that I will not go over these problems.
* Oil change (engine-transmission), all filters (including lpg), front pads - front ball joints, rear wheel bearing, timing-V belt, Crank pulley (this is the main issue), spare key, shock absorbers at the end
NOt: I remember, I live in AYDIN and I don't think they are very reliable in private service, they are expensive in service.
My problem;
1) Knowing friends know how to sound when the strap is loose; I tried quite a lot for this problem, and finally we realized that the pulley was slipping and we changed the pulley, it did not sound for 2-3 months and started to come again when it was full joy. I went to the master again, this time it is okay on the hoop but the same sound occasionally does. I have now become skeptical of the master because of the strap, can it not sound like these originals?
2) Since I bought the car for the first time, there is a sound similar to a buzzing sound, the master says it is normal, but in another 307 this sound does not sound. It is such a sound; it reproduces in the car as it presses the gas, there is no sound when you take your foot off the gas.
3) It smells like a burning smell inside the car, we didn't even go to perfume the filter one day, I wonder if this is because the filter is not original?
I am waiting for your friends half and thank you very much for your help. Good day to all of you ....
08.05.2020 14:58 # 2
I can't say anything to problem 1
2. I'm not sure if the problem could be the turbo
The third problem is to clean the simple air conditioner, there is a product here.
08.05.2020 14:58 # 3
2. Can the problem be caused by exhaust? Is that kind of hum?
08.05.2020 14:58 # 4
nteker
Thank you guys, alone, the voice of this 2nd question is not always elsewhere ahead.
Lanope, I bought an air conditioner cleaner from Hepsiburada, I hope I will use it tomorrow.
08.05.2020 14:58 # 5
onderoto
1. THE BELT MAY BE THE INDUSTRY OR THE PULLEY THAT CAN BE MOUNTED AND THE INDUSTRY CAN BE CHANGED WHEN THE RECOMMENDATION IS NOT THE PROBLEMS, THE MOTOR SHAPES AND THE ORIGINALS FOR THE MOTORCRAFT (FORD VEHICLES IN THE FORD VEHICLES).
2. THIS VEHICLE DOES NOT HAVE A GASOLINE TURBO. CHECK ANY FILTER BOX OR ANYWHERE WHICH IS AIR TO CHECK THE CHARGE DYNAMOE.
3. IF THE FILTER IS SIDE INDUSTRY, IT WOULD BE INSTALLED WITHOUT WRONG OR FULL SEATING.
08.05.2020 14:58 # 6
onderoto
I HAVE SOMETHING THAT I FORGOT.
FOR THE QUESTION 3, THE ROOM HAS A GASOLINE PUMP IN THE BACK, THE ROOM MAY HAVE TO FAIL BETWEEN THE CIRCUIT BREAKS THE CIRCUIT AND CAN PROVIDE A BURN ODOR.
08.05.2020 14:58 # 7
nteker
I bought the pulley from the authorized service, got it installed in the private service so it is original but I can't say anything for the belt because I don't trust that master.
08.05.2020 14:58 # 8
[QUOTE = nteker] Thank you guys, alone, the sound of this 2nd question is not always elsewhere ahead.
Did you buy carpex or stac?
08.05.2020 14:58 # 9
nteker
I bought a stac, I will try tomorrow, I share it in a weekday title, but the friends here are satisfied.
08.05.2020 14:58 # 10
stac is the best you have done well I bought it from it 1 week it smells of lemon then the smell passes but there is no trace of bad smell, especially in summer, the cool smell of the air conditioner comes in zero.
08.05.2020 14:58 # 11
nteker
I used Stac for now, it's a nice product like no problem, but let's see if the same smells will come on the long road, and let me get more ideas from my friends for this 1st and 2nd question. Is this belt noise harmful to the vehicle?
08.05.2020 14:58 # 12
Don't worry, don't worry, I used it for at least 8-9 months.
