sounds
Homepage » PEUGEOT MODIFIED PLATFORM » Virtual Modified
08.05.2020 17:07 # 1
206x-line
What can be done for the squeaks coming from the doors during the driveway roads during the drive to make the door better
08.05.2020 17:07 # 2
ERSOY-06
he had done this work to his friend vehicle named "alliance" and explained it in detail.
08.05.2020 17:07 # 3
Alicilik
Brother misunderstanding. I am not the first to make and explain. There was a title in the forum, I could not find it now. Niyo called brother Kenan used to make the site first and uploaded the pictures. I bought a 10mm (especially I mention) sound insulation sponge in the door. I bought 5mts, 2mtsi fln is enough. Do not allow stretching. There will be a white sponge coating on the inside and remove it so that it does not leave any parts. And keep it to help you with sponge cutting. Protect the electrical parts (not very necessary) and clean the inside with a thinner. Optionally, you can remove the door moldings and use the substance inside. The material you use alone should be water and dust resistant. Carefully cover the inside of the door sheet with bitumen without any gaps. I preferred to use one piece. If possible, there should be no air space and open space. Be very careful when using the tape, it can stay where it sticks. I had a lot of trouble. Cut and paste the sponge. Replace the clips of the door trim with rubbers. And insert it carefully. If possible, work for 2 people, and I worked quite a lot on my own. I spent 2 days in the morning from the morning and the result was great. I have a 2006 feline friend, I closed her door and it was as if I closed her with a piece of metal. My door closes more heavily with a loud voice. !!!!!!! Use synthetic thinner Make sure that the effect of the thinner passes before using the brush. Use it for a short period of time while using our curl, do not melt the substance.
08.05.2020 17:07 # 4
ERSOY-06
bro, there is nothing to be misunderstood, I saw you heard it and I gave you your name because I read it.
08.05.2020 17:07 # 5
ERSOY-06
bro there is nothing to be misunderstood, I saw you heard it and I gave it to you because I read it. I'm sorry if I left you in a difficult situation. Regards & nbsp;
08.05.2020 17:07 # 6
Alicilik
[QUOTE = ERSOY-06] bro there is nothing to be misunderstood, I saw you heard it and gave it your name because I read it. I apologize if I threw the ball on you and I left you in a difficult situation. Even if it is a virtual environment, I am a bit sensitive about selling information that I use as someone else. I did not write very detailed, I wish I would have written his link.
Kenan abi (one of the first to do this job with the name niyo) a person I love so much now sold his car and bought a new astra. I also know the current owner of your vehicle. He valued his vehicle very much. He had very good work.
I would like to share any information I know about this process. Ask my private number and we can talk whenever you want.
& nbsp; Member
08.05.2020 17:07 # 7
Alicilik
Here is the work I mentioned:
http://forum.peugeotturkey.com/forum_posts.asp?TID=16408&KW=bit%FCself&title=kap-ses-yaltm-zml-images -2page Reviews
08.05.2020 17:07 # 8
ERSOY-06
My dear brother, I did not say I did not say that someone else did not, I just mentioned you because I know that you did it.
