Sound when turning 307 steering wheel
08.05.2020 17:16 # 1
leffe
Hello.2 I have a problem:
I have a 2003 model 307xr gasoline owner. When the vehicle is in motion, when I slacken the steering wheel slightly to 1 o'clock, there is a noise in the form of a gnawing from the front right. If I flip it a little more or fix it, the sound disappears. There is sound only when I hold it at a certain angle. What could be the reason for this?
& nbsp;
And when I pull my feet out of the gas, I hear a buzzing sound sometimes. I wonder why this is too.
& nbsp;
Thank you. Reviews
08.05.2020 17:16 # 2
falan
If the idling is falling or rising during these sounds, it is generally accepted as a normal situation .. because the steering hydraulics gets its power from the engine and the vehicle loosens automatically when the engine loses power.
& nbsp;
Reviews
Reviews
Reviews
08.05.2020 17:16 # 3
xMEGANx
My normal brother. & nbsp;
08.05.2020 17:17 # 4
leffe
When you say normal? shouldn't I wear it?
08.05.2020 17:17 # 5
impact
Walla I was coming up with that deterrent. I changed the crank pulley in the first run. The sound was cut but after 3 months the steering wheel turns again, the thought is routine ..
08.05.2020 17:17 # 6
sabri_23
I had the same sizzle on me, I removed the cover behind the steering wheel, if you lift your head up and look at it, there is a roller rotating with your elbow.
08.05.2020 17:17 # 7
cavit cevo
In 2003 models, I know that the steering wheel has an electric pump. I think it has nothing to do with the engine pulley.
08.05.2020 17:17 # 8
cavit cevo
when you take your foot off the accelerator pedal, the buzzing sound may be a clutch ball or gearbox
08.05.2020 17:17 # 9
lamazibici06
There is a steering pump malfunction. I have that same problem
