SOUND WHEN THE STEERING WHEN GOING ON THE ROAD
08.05.2020 17:57 # 1
tredi
Hello to everyone. 307 1.4hdi 2003 model 172000 km on my vehicle while driving on the road, there was a thin buzzing sound. Yesterday I took it to the master said from the front wheel balls, we changed both of them. We also made rot balance adjustment. but still continues. When I went again, they said it might be from the tires, but it did not go to my logic. because I know the sound of the tire. I also replaced the two front tires. there was in the previous one too. As it sounds humming in this, it is in a fine vibration. If you have experienced friends, I would like your help. thanks.
08.05.2020 17:57 # 2
leffe
classic steering pump problem. I don't know if there are 307 owners. I got used to it. More knowledgeable friends will help for the solution.
08.05.2020 17:57 # 3
tongucuk
again, the case of a master breakdown has been made from the balls, the money you have bought, you have taken the tire, when the sound goes again, it tells you that there are no rims, no bows etc etc. When you get out of the work, your friend says that your car is damaged from the front, you will not get used to this sound while you are getting your car. he can even say i don't hear anything
Don't think I was kidding bro, I'm worried about the master, I wrote what was said to me
08.05.2020 17:57 # 4
tredi
I say to the masters. call me this sound normal i ride like this but they can't say. they say it is not normal. they don't know why. I have been riding this car for a year. everybody says something. No axles, no balls, no rubber, no gear, everyone says something. I had opened a topic here again before. the vehicle runs for a few seconds and then stops. Believe me, they did not say injectors, they did not say fuel shamanma what they said, it turns out that they were taking air from the connection point to the fuel filter. I made 50 liras a year later, the problem is over. we would go 2000 dollars if we do what everyone says. and again the problem would continue. then consider the problem with the master.
08.05.2020 17:57 # 5
kuscu38
God save you about the master :)
08.05.2020 17:57 # 6
TaZ
You can easily understand that the balls of the vehicle have been distributed in a simple and inexpensive way.
08.05.2020 17:57 # 7
tredi
I went to the master again today. We changed the tires, we set off and the sound continued. It was certain that it was not made of tires. just like the wheel. I don't know what will happen if it continues to change.
08.05.2020 17:57 # 8
tredi
the rear wheel ball has changed but the problem has not been solved. There is no sound from here. Apparently we'll get on like this.
08.05.2020 17:57 # 9
jiyanxese
can also make from discs and brake pads
08.05.2020 17:57 # 10
tongucuk
teacher, did you look at the steering fluid, is there any leakage reduction?
08.05.2020 17:57 # 11
metin
It happened to me, not the steering pump. While driving on the intercity road, there was humming in the corners. The problem came out of the pad.
It was making humming by rubbing the disc in the bends, we got it done and did not do it again. (Vehicle: 2004 model 307 1.6 XT)
08.05.2020 17:57 # 12
tredi
They said we looked everywhere, the balls changed. The front team has been completely checked, and met with other masters. Finally, the master give up. Look elsewhere or such a thousand said.
08.05.2020 17:57 # 13
tredi
what you said made sense to me, but I wonder if the disc has just changed the system. The sound comes in light steering movements on the straight track. how did you solve it?
08.05.2020 17:57 # 14
pusutr
Hello there. I think your car has no problem parts. The salıncaka / axles /? a screw holding it is loose. I think you can remove the front wheels and check all the screws. something like this happened in my friend's car. They removed the right wheel, checked the screws, and one of them came loose. They are clenched well and happy ending.
08.05.2020 17:57 # 15
tredi
Let's look at the industry now. They said they bent down to the front hub and they would change it and look.
08.05.2020 17:57 # 16
just as the problem starts with the pad and let them get used to the parts of the pad then they will understand, then the problem disappears Wink
08.05.2020 17:57 # 17
tredi
The disk has changed the week. BEFORE THERE WAS ALSO. IT WAS NOT AFTER CHANGING.
08.05.2020 17:57 # 18
metin
My pad had just changed, our so-called master who did not wear a pin or spring on the pad. I noticed when changing the Z-rods of the vehicle, it was playing the lining. Then I took care of the service and there was no problem. I think check with the hand from the outside is the lining on the lining.
Note: Make sure it is not hot (:
08.05.2020 17:57 # 19
tredi
Friends brought to another master today, they said they were doing everything about the ten layouts, the only thing left was sanjiman. They say there is no other place left. 500 tl was the money that went to the base. They say 1000 liras in sanjimanda. I'll say let's change it, but if it doesn't happen.
08.05.2020 17:57 # 20
pusutr
I think it is useful to ask another master. never again, another master. I hate money paid in vain. as if we cut the money off the trees.
Page : / 2
