Sound When I Turn On The Contact ..
08.05.2020 16:35 # 1
burakdmr
Hi guys .. I am facing a new voice :) I turn on the ignition. A strong DINNN sound is coming without starting the starter.
08.05.2020 16:35 # 2
burakdmr
Let me note that the Lpgnin fuse was blown. I replaced it with a 30 amp fuse. Can it have something to do with it ???
08.05.2020 16:35 # 3
yavuz25
I don't think it is related to insurance.
08.05.2020 16:35 # 4
burakdmr
As if I had read an error like VAlla antivoltage in the vehicle for a moment ... we had removed the poles and then there was a problem.
08.05.2020 16:35 # 5
burakdmr
Yes, in the first contact, an article like Antivoltaj appears, all the indicators become darker, and then it gets better again. I wonder if there is a problem while wearing the polar heads.
08.05.2020 16:35 # 6
yavuz25
Didn't you follow the pole removal and installation order?
08.05.2020 16:35 # 7
burakdmr
Well, there was no problem with the battery. Even in this cold, I would take it for 5-6 days. I took it at once. I left the battery to charge.
08.05.2020 16:35 # 8
burakdmr
my abs lamp was burning maybe it has something to do with it
08.05.2020 16:35 # 9
yavuz25
low amperage can cause the brain to deflect.
08.05.2020 16:35 # 10
okankrgz
the gas pump makes a buzz in the form of sound, I recommend that you start it when the car is half contact, if the sound stops, if it comes from the pump, of course but it may be relevant in the brain
08.05.2020 16:35 # 11
savi_206
[QUOTE = yavuz25] Didn't you comply with the pole removal and insertion order? [/ QUOTE]
how is this procedure?
08.05.2020 16:35 # 12
yavuz25
[QUOTE = savi_206] [QUOTE = yavuz25] Didn't you follow the pole removal and installation order? [/ QUOTE]
Reviews
http://forum.peugeotturkey.com/forum_posts.asp?tıd=20338&title=aku-kutup-baslarini-sokerken-3-dakika-kural the
It writes here. "Wink Thank you Özgür brother has found.
08.05.2020 16:35 # 13
burakdmr
I guess friends, I have nothing to do with the battery, I open the ignition again.
08.05.2020 16:35 # 14
burakdmr
In addition, when he turns the ignition, he knocks the doors :)) There was no problem until yesterday.
08.05.2020 16:35 # 15
I don't want to ask, but I find it useful to ask. Was the insurance you taken out 30 Amp?
08.05.2020 16:35 # 16
burakdmr
Well, I put the temporary fuse 30 instead of the fuse I removed from the tube, then I changed it again.
08.05.2020 16:35 # 17
burakdmr
In the meantime, if it is time for maintenance, does the sound alert when the ignition is switched on, do not remember exactly ??
08.05.2020 16:35 # 18
burakdmr
He also measured the battery value 14 outputs, there is no problem in it .. But he has not just started the car for 30 minutes, he did not take the car twice, and gave an error called ANtivol. I don't understand, it's gone .. & nbsp;
08.05.2020 16:35 # 19
[QUOTE = burakdmr] Well, I replaced the fuse I removed from the tube 5, I replaced the temporary 30, then I changed it again .. 30; If we assume that I removed something in amperage, the trouble is big:)) [/ QUOTE]
You must be kidding. In other words, the wave is not with us, but with an engineer who does not replace 30 Amp fuse instead of 5 Amp fuse.
08.05.2020 16:35 # 20
burakdmr
I asked him if there was a problem, we are wearing 5 amps so he can throw it away quickly. & nbsp;
Page : / 2
