sound system related
08.05.2020 14:13 # 1
yigit1989
Greetings to all, I will have a question for friends who understand this work.
In my car, there is a broken CD changer at 307, and I have 4 230 watt 16 jvc jeeps as speakers.
in my car treble the sounds are very good but bass does not hit you do you think what I want to do in general is bass like bass like normal vw bass is enough so i don't want much exaggeration what do you think i should do,
regards
08.05.2020 14:13 # 2
jbl 1100 w gt5 series you will get a bass you will get 150 tl + 150 tl and a 4 channel amp will come to you 350 tl with your warmth and caplomas.
they only attach an apparatus behind the tape for connecting tape sampler amps and bass and for beautiful feeds, but I do not recommend it to the original without changing it.
08.05.2020 14:13 # 3
H-a-d-i
If the tape's power was enough to hit the bass, it would sound bass. I do not think there is a problem with the speaker. I think the cheapest way is to buy a Pioneer CD player. It doesn't even cost 200 TL.
If not, you should get an amp and woofer. keeps at least 400 TL.
08.05.2020 14:13 # 4
hakann308
[QUOTE = Come on] If the tape's power was enough to hit the bass, it would sound bass anyway. I do not think there is a problem with the speaker. I think the cheapest way is to buy a Pioneer CD player. It doesn't even cost 200 TL. If there is no
then it is necessary to get an amp and woofer. it keeps at least 400 TL. [/ QUOTE]
I don't really understand the answer, obviously the power of the tape is enough to hit the bass ???
& nbsp;
You can not get the bass feeling like the vw group with the original speakers or afterwards, you need a woofer in an amp and one, but if you say I don't want to listen to bass bass, it is more practical and cheaper. I can find way solutions
08.05.2020 14:13 # 5
H-a-d-i
The original CD player can feed these speakers because the RMS values of the original Pejo speakers are not very high. so bass can hit.
but if you take a mid set and wait for the bass without changing the tape, it will not be able to feed the speakers with high RMS values anyway.
So instead of raising the output power of the main unit, simply improving the quality of the speakers only clarifies the sound, never increases the bass.
I meant that.
08.05.2020 14:13 # 6
BuRCaK
I have a cheap and very clean bass and treble system. You can do something like this.
SONY CDX-GT424U MP3 player with usb input - 250 TL
JBL 1000w 30 cm cabinet subwoofer - 185 TL
JBL 16 cm mid set on front doors - 150 TL (rear doors original speakers are connected but dimmed from the tape)
XETEC 800w 4 channel amplifier - 190 TL
WORKING CABLES INCLUDED 150 TL
you can install similar things.
BuRÇaK 2010-04-17 17:46:51
08.05.2020 14:13 # 7
Sufficient bass is not received from any speaker not supported by its amplifier.
Satisfactory defense requires a suitable system for receiving treble, mid, bass and an amp with proper w. systems, we used the fabricated Chinese business vcd player while playing the inter-stage tracks. The sound would not be disrupted ..
08.05.2020 14:13 # 8
yigit1989
Thanks for the answers given, let me ask a direct question because there was a bit of inconsistency in the answers given :)
How can I hit my 230 watt jvc speakers in the cheapest way in the vw group.
Can I change the tape and get an amp?
or what should I add to the existing tape
< / div>
Bidet has no subwoofer in vw's is it necessary to have it installed?
08.05.2020 14:13 # 9
To get bass sound, you need to take an amp + a bass-side subwoofer + a ponyone sony-style tape with strong sound xs. this akdar bast;) EmRaH 2010-04-18 07:31:22
08.05.2020 14:13 # 10
hakann308
[QUOTE = yigit1989] Thanks for the answers given, I would ask a direct question, because there was a bit of inconsistency in the answers given :)
Wouldn't I change the tape and get an amplifier?
Bidet does not have a subwoofer installed in vw's.
thanks
you don't need to change the tape, you will get an amp output on the tape, you will get an amp, for example, edison and & nbsp; jbl you will get 1000s of bass whenever you want, you can dim the bass when you want, you can listen like a vw group and open a bass as you like, or you can install a facility like mine. You will travel in the festive mood
& nbsp;
hakann308 2010-04-18 12:20:15
08.05.2020 14:13 # 11
BuRCaK
[QUOTE = hakann308] [QUOTE = yigit1989] Thanks for the answers given, let me ask a question directly because there is a bit of inconsistency in the answers given :) .
or what should I add to the existing tape < / div>
bidet vw does not have a subwoofer, is it necessary to install it?
thanks
No need to change the tape, you will get an amp output on the tape, you will get an amp, for example, edison and & nbsp; jbl you will get 1000s of bass whenever you want, you can listen to it whenever you want by turning on the bass, or whenever you want. You will install a plumbing like mine, you will travel in the festive mood
& nbsp;
When everything hits beautifully, those ferrari are not playing? "Grin" have you fixed them?
08.05.2020 14:13 # 12
hakann308
[QUOTE = BuRÇaK] [QUOTE = hakann308] [QUOTE = yigit1989] Thanks for the answers given, I would ask a direct question because there was a little discrepancy in the answers given :) How can I hit the bass in the vw group.
Can I change the tape and get the amplifier?
or what to the current tape I need to get additional like
thanks [/ QUOTE]
no need to change the tape, you will get an amp output on the tape, you will get an amp, for example, edison and & nbsp; jbl will receive 1000 bass whenever you want by turning the bass down whenever you want, like in vw group. You can listen loudly or you will install an installation like mine. You will travel in the festive mood
& nbsp;
when everything hits beautifully, those ferrari are not playing? "Grin" have you fixed them?
no they do not play, they will fix it from their place, but I will change them, and I will take them from the die-cast of 308 rcz, and install them
08.05.2020 14:13 # 13
yigit1989
I looked at the tape today, but I realized that changing the tape is so ugly that I decided to clean the current cd changer and use it. Yes, my dear masters, how can I get the best sound with the current tape & nbsp; :)
08.05.2020 14:13 # 14
BuRCaK
It will not be much different than now, if you are not going to wear an amp and mid. I also don't understand where an ugly image is. I will add photos tomorrow. more beautiful than the original. the tape you looked at was not good.
08.05.2020 14:13 # 15
BuRCaK
picture of my tape. I don't think it looks ugly. because its lights are orange, it even harmonizes. in my opinion. I say something like this and anfi mid sub team is essential for bass.
08.05.2020 14:13 # 16
yigit1989
Believe in 307, it looks very ugly, and the cd & nbsp; changer and arm control will be wasted :( I am surprised what I do or the amplifier or the original speaker yaw
08.05.2020 14:13 # 17
BuRCaK
this tape was attached to my old 307 vehicle :) If you're not going to take the big screen and put it on completely, the changer should stay there.
tape is not looking for the remote control arm already, it is very comfortable. When I drive with one hand, I change it with the other hand.
I just shared my opinion, my friend. but you will not regret it if you say so.
BuRÇaK 2010-04-21 22:07:19
08.05.2020 14:13 # 18
cerci07
With the help of a small apparatus in the original tape, you can connect the amplifier and the sound supplement you get will be better than before or you can double the sound you get with a tape recorder only. "http://www.sahibinden.com/original_your_anfi_cikisi_yokmu_iste_cozum_by_kocaman-77WQQaXQQ24369323WQQpXQQdisplayitem" target = "_blank"> http://www.sahibinden.com/orjinal_tey_iniz_is_an_came
08.05.2020 14:13 # 19
yigit1989
I have a very logical question for you,
there is no amplifier or something in these new vws, but what a nice bass is hitting me, I want to have my bass on these doors, I don't want to enter the trunk or something. I looked today I have a black tape with 200 tlye orange indicators
08.05.2020 14:13 # 20
b55can
[QUOTE = BuRÇaK] is the picture of my tape. I don't think it looks ugly. because its lights are orange, it even harmonizes. in my opinion. I say something like this and anfi mid sub team is essential for bass.
Page : / 2
