Sound system malfunction.?
08.05.2020 15:59 # 1
Engin Tepe
My dear friends;
I have been having trouble with my audio system for 1 month in the last 1 week,
Namely,
Total 30 vol. while there is an average of 15 20 vol. The sound of the door pillars is cut between but the bass (amp) is active,
when I get the volume from 25 to 25 and over, it comes back,
Also, when I change the cables, the same trouble bass goes through the amplifier, when the sound makes normal again 25 25 vol, it is backward at the last sound limits.
What is the disease, will the doctor live .....
Engin Tepe 2011-08-14 21:47:58
08.05.2020 15:59 # 2
34sea45
you can probably protect it because the amp is not enough, and most of the interruptions are because the amperage is not enough, I try to help you better if you write the exact parts of the system.
08.05.2020 15:59 # 3
Although the protection circuits of the amphitheater are burning, the sound is the same thing that you said, I happened to me. Then I mixed the amphitheater's manual a little bit, I came across it, this is not a problem, it is not a problem. burak.bülbül 2011-08-14 22:06:20
08.05.2020 15:59 # 4
34sea45
As long as there is such a thing, pleasant music is not listened to in the system. It means that the amphitheater connected to the protection of the amp is too much.
08.05.2020 15:59 # 5
Engin Tepe
The amp has only 1000 W jbl bass of 1800 W and they have 2 sunny speakers, and they burst, and we've given 30% power over the amp. At first, I did not have such a problem for 3 weeks besides neither did the last voices.
There is a tape original converter,
Insurance,
Amp bass
Engin Tepe 2011-08-14 22:15:47
08.05.2020 15:59 # 6
34sea45
What is anfini brand? you bought the products
08.05.2020 15:59 # 7
Engin Tepe
Products bought from our 2nd hand here, come out of 307
08.05.2020 15:59 # 8
34sea45
Sorry, the pictures have not been seen. I think there may be a problem with the deck cable. When the deck is problematic, everything is normal in low voices, while loud sounds can go, but most likely there is a problem in the amplifier.
08.05.2020 15:59 # 9
Engin Tepe
He said that it was necessary to open the amp completely and the room was not required yet.
The sound sounds tickling in the 15s, but if we give full sound, the back will come back, and it does so often not in 1 2 days.
08.05.2020 15:59 # 10
34sea45
there is probably a problem with the deck cable but in general an amphitheater should be reviewed
08.05.2020 15:59 # 11
Engin Tepe
Okay, I'll show you tomorrow early tomorrow. What is the problem?
Thank you brother for the information.
Tomorrow I will fix the breakdowns and theta.
08.05.2020 15:59 # 12
34sea45
These are the problems that most of the installers have experienced. In fact, when we installed and disassembled 7 8 times, we got a little defect.
08.05.2020 15:59 # 13
Engin Tepe
God willing.
08.05.2020 15:59 # 14
Uses the audio harness while the vehicle is running. Driving with the vehicle stopped.
Go to a competent electrician, scan the sound system from start to finish, there is definitely a problem.
08.05.2020 15:59 # 15
34sea45
When using the vehicle when it is stopped?
08.05.2020 15:59 # 16
[QUOTE = 34sea45] When using the vehicle with a stop? [/ QUOTE]
I meant to use the sound system without starting the car.
If the car sound system is strong and you are listening to music at high volume, it will force the battery.
08.05.2020 15:59 # 17
34sea45
3 sets hertz mid 2 sets alpine column 1 kicker l7 bass is not a problem here only the level of sound is important i think
08.05.2020 15:59 # 18
Mesut
I was experiencing the same problem in the meeting of Pasa sa Antalya. I guess you have the same problem, let the pasha go to the installer and find the tool in two minutes.
08.05.2020 15:59 # 19
34sea45
room probability of course without the complete overhaul of the system.
