Sound system help for Peugeot 206 [Single Door]
08.05.2020 18:21 # 1
canmert
I think the sound system for the Peugeot 206. I couldn't make a decision because I was researching too much. My budget is 2000 TL. I think in the form of a box bass or I will double the price and buy a 38 Cm Subwoofer. Let the sound heart I want to hop on and the alarms will sound :) I am waiting for your suggestions .. Myth team + Subwoofer + Anfi. I have tape. Thank you from now. Respects...
My opinion: JDL brand 5-channel amplifier for Anfi.
JLD-6515 6,5 INC COMPONENT SET (for two front)
6.5 "16,5cm 2 Way Component Set
Aluminum case
80 Watt RMS
JLD-6930 6x9 INC COMPONENT SET (for two backs)
6x9 "2-Way Component Set
Aluminum case
150 Watt RMS
500 Watts
JLD-H12 12 "30CM BASS
12 "30 CM SUBWOOFER
METAL CASE
650W RMS Power
1500W MAX Power <
NOTE: Instead of the subwoofer, I can double the price and consider a bass of 40 cm. Bass Amplifier + 38 Cm Subwoofer
canmert 2014-03-05 20:06:47
08.05.2020 18:21 # 2
Bugra
open a topic, introduce yourself, let's see who are you? You can install 2 thousand glass glass-blasting installations. What do you do for that money? Wink
08.05.2020 18:21 # 3
canmert
I do not know much about using a forum :) But believe me, I have been researching for days until isolation, but I can't get what I expected with a system of 2000 TL.
Fix: Okay I introduced it :)
canmert 2014-03-05 20:18:01
08.05.2020 18:21 # 4
Alicilik
What is this JLD? I heard first time.
You will get loud noise with the set you mentioned. But you need a very good amp for these. Even 1 is not enough. You need to buy mono + stereo. If you feed that bass with a 5 channel amp and other speakers, it will probably become coal in 15 minutes.
For hard sound, I call JBL and Kicker.
08.05.2020 18:21 # 5
barishrocker
2 re audio sex12 do a good job with a monaural amp and 2set mid-set, 4 channel amp, and a pioneer tape with 3 outputs. It is necessary to take the cables with high quality and to insulate the doors and trunk. I have never heard of that brand.
08.05.2020 18:21 # 6
EmSul
The friend mentioned the 2000tl, the price is doubled, and the friend is in search of a high-quality system. You can even connect it to the tape output, it will sound as much as the given power. If there is something burning, it is a connection and adjustment error.
Forget the brand you call Jld directly.
Our peace friend's suggestion is exactly like you point shot, re audio sex or mtx 7515 dd 9515 rockford t2 etc ... But in a small car like 206, I think it would be much better to choose 2 25cm bass. the kicks are taken in the small vehicle 2 can be 25cm cvx te as mono amp dd z1 cadence daytona etc .. as mid team 1 set 3 way can be your work hsk 163 or focal krx3 but the options are too much decision a bit difficult
08.05.2020 18:21 # 7
barishrocker
True 206 small vehicles would be enough in sex10. I use hsk163. There is also a zero in the friend, I can steer .. krx3 is also nice but the price is unnecessarily high I think
08.05.2020 18:21 # 8
barishrocker
2 re audio sex10d4 and orion 2500d mono amps play very bad ..
08.05.2020 18:21 # 9
canmert
I researched all of the JDL brand, including JBL and Kicker. I put them all side by side and checked them from interior design to coils, the most successful of them is JDL brand. I have read the comments, but 2000 TL will not show anything big in your eyes. Go to the brand you want with myth set + Subwoofer + Anfi + Installation + Cables. A 2000 tl installation is like this, whether it's Kicker or JBL. As I said I trust the JDL brand, I researched everything. Including sound quality. But let's say the Subwoofer sounds like little. There is another bass of 38 cm 3500 watt 2000 RMS, but to get it installed, we also give the bass amplifier + isolation + battery or something, and with the bass, we give an additional 2000 TL and together with the other, it reaches approximately 3000 TL. The total cost comes to 5000 rubles. As you say so, 2000 TL glass explodes and you can be sure that you will get a great sound :) You can be sure .5000 TL is like a heartbreaker but I am asking you to be knowledgeable friends. My goal is to jump heartily, to shake the cars outside, to do this with the least cost of course :)
08.05.2020 18:21 # 10
canmert
[QUOTE = Buyer] What is this JLD? I heard first time.
Let's say the treble perfect bass that we have run with a beautiful lecture is lagging behind. More precisely, it lags behind for me. I can say that I haven't heard a better treble than this right now.
08.05.2020 18:21 # 11
canmert
[QUOTE = barishrocker] 2 re audio sex12 work well with a mono amp and 2 set mid kit, 4 channel amp and 3 rca output pioneer tape. It is necessary to take the cables with high quality and to insulate the doors and trunk. I have never heard of that brand .. [/ QUOTE]
I think the system you said seems to exceed 2000 TL. In addition, two bass look bad except for 40 and 38 cm. Therefore, we need to take a single bite and look at our pleasure :)
canmert 2014-03-06 13:48:34
08.05.2020 18:21 # 12
barishrocker
I guess you do not know the taste of double sub, you are talking like that :) anyway you have already determined in your mind. I can not comment on the brand that I do not know .. by the way, 5 bass can not receive such a bass. 5 channel amps are not made for that purpose, their power is limited.
08.05.2020 18:21 # 13
canmert
[QUOTE = barishrocker] you do not know the taste of double sub, I think you are talking like that :) anyway you have already determined in your mind. I can not comment on the brand that I do not know .. by the way, 5 bass can not receive such a bass. 5 channel amps are not made for that purpose, their power is limited.
What do you think the 30 cm double sub can taste is also losing from the sight :)
08.05.2020 18:21 # 14
barishrocker
Then let me make another suggestion put 4tane 20 or 25cm :) I don't like spl but I follow it from friends. Now the only 38cm is out of fashion :) last friend put 8 on station wagon re sex from the sub guys :)
08.05.2020 18:21 # 15
barishrocker
Apart from that, there are sub-branded subs, you can use them only;) but it would be a pity for the car. If there is a sunroof, it will malfunction :))
08.05.2020 18:21 # 16
canmert
[QUOTE = barishrocker] Other than that there are sub-branded atomic handles you can use them only;) but it would be a pity for the car. Sunroof, if any, was malfunctioning:)) [/ QUOTE]
Hhahah look beautiful this :) Now what do you say, if you write exactly with their brand, I have my research. I did a lot of work but you know this job well :) :)
08.05.2020 18:21 # 17
barishrocker
We are learning with such exchanges .. friends, me, I, you, someone else and so on :)
As I said if you say 2 get sub, 2 re audio sex12 and orion 2500d would be very nice. Atomic had friends but was sold. Let me learn and write the exact model
08.05.2020 18:21 # 18
barishrocker
38cm atomic hand was passed as 15 .. Double 2ohm coil 2000w rms power 550tl to another friend .. I need to feed this again with orion or worst macoustic 2000.1 or cadence 2500.1 ..
08.05.2020 18:21 # 19
canmert
[QUOTE = barishrocker] 38cm atomic hand is passed to 15 .. Double 2ohm coil 2000w rms power 550tl to another friend .. I need to feed this again with orion or worst macoustic 2000.1 or cadence 2500.1 .. [/ QUOTE]
ok I had 38 bass that I found what I said a research, 3000 watts 2000 RMS power, you have to compare them. thank you for your help
08.05.2020 18:21 # 20
asi kiz barbaros
hi, i am a new member and i bought my first 307 black rebel girl i made atiker sequential system i got gas from a friend sony usb li cd player (120 tl) cadens square bass (150tl) kenvood amp (250tl) rakford fosget 2ad sab I had the same brand anfim kenvud cd player but it definitely has nothing to do with this new installation. It is a strange thing that jumps off the heart of the people. Let's take a tour that sees my car. Let's go to the street. Gather by me, have a great installation like me. I respect you
Page : / 2
