Sound system help.
08.05.2020 17:56 # 1
cybermaniac
Hello friends...
I have a 2005 model 206 xt vehicle. I think this is the sound system, but I don't understand from the sound systems. I guess. Now when I search on google, I have seen the sale of some package systems that I have seen on sahibinden.com. First of all I want to consult them.
Should I change 1 tape? What do you suggest ?
Should I have 2 columns in a row?
3 mid-team is out of the column they call or if the columns are called mid-team, should I get both the colon and mid-team?
There are brands like hei roadstar as 4 amps, what can be the affordable amp?
What do you think about the links of the products I found? Also, can you send me a ready-made package system? Or if there are friends from Istanbul who do this job, can they give me a price? Please, I would be glad if you could help.
http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-ses-sistemleri-paket-sistem-sok-sok-pioneer-sette-sok-kampanyaa-hepsi-bu-fiyata-kacirmayin- 107033625 / detail /
http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-ses-sistemleri-paket-sistem-dunya-markasi-jbl-komple-sette-kampanya-ozer-car-audio-da- 121377540 / detail /
http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-ses-sistemleri-paket-sistem-komple-set-ismail-berke-den-pioneer-roadstar-103496638/detay
http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-ses-sistemleri-paket-sistem-pioneer-full-set-kablo-takimi-hediye-kapinda-ode-sok-kampanya- 136977866 / detail
08.05.2020 17:56 # 2
cybermaniac
http://www.hepsiburada.com/liste/pioneer-dxt-1569-oto-teyp-ve-hoparlor-set/productdetails.aspx?productıd=otpiodxt1569&categoryıd=26080&navq=fh_location%3d%252f%252fcatalog01%252ftr_tr%252fcategories% 257bcatalog01_60002705% 257D% 253C% 253C% 252fcategories 257bcatalog01_60002705_2147483631%%% 257D% 253C% 252fcategories 257bcatalog01_60002705_2147483631_253575 252fcategories%%% 257D 257D% 253C% 257bcatalog01_60002705_2147483631_253575_26080 252forder_stock_attribute_pl%%% 252fitem_sale_count_pl 253d1.0 253e1.0% 252F%! 892_dp 253d%%% 257blisteden20c70131kar0131ls0131n 257D% 26fh_view 3ddetail%% 26fh_refth average% 3d792aa7c5-b37b-48ab-8fd7-27b38dbac36 to 252cdetail%% 252C% 252F% 252fcatalog01 is 252ftr_t% 252fcategories%% 253C% 257bcatalog01_60002705% 257D% 252fcategories% 253C% 257bcatalog01_60002705_2147483631% 257D% 252fcategories% 253C% 257bcatalog01_60002705_2147483631_253575% 252fcategories%%% 253C 257D 257D is 3dlist 257bcatalog01_60002705_2147483631_253575_26080%%%%% 26fh_refview 26fh_sort_by 3d-item_sale_count_pl 26fh_secondid%% 3dotpiodxt156 3d26080% 9% 26categoryid
I also picked this up with the amp and bass wrap next to this set, or would it be without them?
08.05.2020 17:56 # 3
Alicilik
[QUOTE = cybermaniac] http://www.hepsiburada.com/liste/pioneer-dxt-1569-oto-teyp-ve-hoparlor-set/productdetails.aspx?productıd=otpiodxt1569&categoryıd=26080&navq=fh_location%3d%252f%252fcatalog01 252fcategories is 252ftr_t%%%% 257D% 253C% 257bcatalog01_60002705 252fcategories 257bcatalog01_60002705_2147483631%%% 257D% 253C% 253C% 252fcategories 257bcatalog01_60002705_2147483631_253575 252fcategories%%% 257D 257D% 253C% 257bcatalog01_60002705_2147483631_253575_26080 252forder_stock_attribute_pl%%% 252fitem_sale_count_pl 253d1.0 253e1.0% 252F%! 892_dp 253d% 257blisteden20c70131kar0131ls0131n%% 257D% 26fh_view 3ddetail%% 26fh_refth average% 3d792aa7c5-b37b-48ab-8fd7-27b38dbac36 to 252cdetail%% 252C% 252F% 252fcatalog01 is 252ftr_t% 252fcategories%% 253C% 257bcatalog01_60002705% 257D% 252fcategories% 253C% 257bcatalog01_60002705_2147483631% 257D% 252fcategories 257bcatalog01_60002705_2147483631_253575%%%% 252fcategories% 253C 253C 257D 257D%%% 257bcatalog01_60002705_2147483631_253575_26080 26fh_refview is 3dlist 26fh_sort_by%%%% 3d-item_sale_count_pl 26fh_sec ondid 3dotpiodxt1569 26categoryid%%% 3d26080
I also picked this up with the amp and bass wrap next to this set, or would it be without them? [/ QUOTE]
With this system, you will only get a little higher quality and loud sound, but I don't know if it meets your expectations.
The sound system is an endless torch shaped by demand and material. Even a company produces 4-5 kinds of speakers equally, its purpose is to appeal to the ear and pocket.
If you want a little more noise in your budget range, a system can be made to meet your demand.
An OEM aftermarket tape replacement is a must if you are not happy with the tape and really want the feature and some power. You cannot take the original tape beyond the original image. You will also drop the low power audio output with a converter.
After shaping the tape in your head, you should go to the wiring and speaker. Compenant speakers use slightly different materials and systems due to their structure, and there are crossover processors that change the signal by a degree. For this, you separate the mid and high frequencies and transfer it to the woofer and tweet.
It changes in 2-3 ways. My advice is 2 way (Woofer16cm-Tweeter2.5cm-Crossover)
With this, you can listen to the middle and high frequencies more deeply and clearly. Since the frequencies are not overlapping and close, you can hear the sound better from different angles.
My advice would be the component set for the front doors. If you can budget, "JBL 6508c" is my only suggestion.
Instead of putting it on the back door, oval speaker set can be placed on the trunk upper cover guard. You get more and better sound.
Brands such as Pioneer-kenwood-alpine-sony-JBL can be preferred.
The oval column meets your bass request to a certain extent, but as I said, this is proportional to your expectations. When installing the system, specify your request to those who make adjustments.
As an amp, a similar subject has been discussed before. Another friend wanted to do something to your car like you. We are installing a pioneer system for it. The amps in that class you specify as amps are the same as 3 down-5 up. Materials that give performance according to the price. Obviously, I would buy the one with the best view and price. Of course, the nominal basis (RMS) outputs should be at least 50w.
Improve the system a bit in mind, the outputs of the amps and speakers should be equivalent, but to achieve this is a low budget problem, so the amplifier can be lower and the speakers can be more powerful, which increases your amp requirement over time.
The 4-channel stereo amplifier you will receive on BAss can be bridged and still lift a bass up to mid-range 300w rms.
08.05.2020 17:56 # 4
cybermaniac
First of all, thank you for the answer you gave. I visited the places that made some auto music system in the caglayan region of Istanbul. They talked about the lowest 850 prices, hei, flippo, roadstar sets. They said that no amps and bass can be followed to the tape and speakers in the pioner package ... I was surprised what I would do .... what can be followed as amps and bass on the pioner set at the last link I gave. Is it true or did they try to mislead me to sell the goods they have?
08.05.2020 17:56 # 5
Alicilik
If a good geologist comes to me, if there is a situation that will affect my job, I would not be friendly to the man next to me, so this is your situation.
Let's return to you tomorrow
08.05.2020 17:56 # 6
cybermaniac
[QUOTE = Appealing] If a good geologist comes to me, if there is a situation that will affect my job, I would not be friendly to the man next to me: D this is your situation.
I am waiting for your answer because I have a lot of questions to ask :)) If you have any information about blow offs, I will have questions about that, but my priority is the sound system :) I have no people around to help me. The person says bad, I'm stunned
08.05.2020 17:56 # 7
Alicilik
Hodja good morning,
Sorry, I was about to sleep now.
I examined the tape. It has RCA output but 2v. You cannot get efficiency with this output. But as I said, it is not possible, you cannot get a full efficiency.
I am very angry with Chinese policy. Excuse me, even when the frost in our ass comes from China, it makes me crazy that the nation is still saying this china. Those who talk to China use the crackling ayfon and watch the sunshine and listen to the pioneeri. Is Pioneer produced in Mars? Made in japan is gone.
Apart from Pioneer, there are many companies that have set their hearts on the sound system vibe-soundstream-magnat-powerbass-JL-rockford, although most of the materials they use are based on Chinese hammering.
I always say the sound system plays the efficiency and material budget you want to take the biggest role. You buy the set in HB again and listen to the music. Hi-Fi is not a system, of course, you can hear certain frequencies. When you turn up the sound the last sound you provide a certain decibel.
When you add more money to work and build an ampenantic system with amplifiers, you hear more frequencies, approaching Hi-Fi and producing higher decibel levels. In the first system, you will receive the volume at 60 and the volume in the amplifier system at 20.
My brother "ramazan" Yenice also has the heading that he had gone yesterday. They used the Roadson amp to say that he had left the pioneer factory, even though I did not know the exact output. Doesn't HA work? Sure, of course. There may be frequent frequency losses when you run at full power, but it will still amplify the sound.
As I said the system sold in HB will certainly be better than the current system. Decide if you are going to connect bass to pick up the bottom tones or to say rumble, let's draw a route like that. Because I connect my MP3 player to the amplifier, the car is going down again, not necessarily tape. Tape is for reflecting quality sound only.
08.05.2020 17:56 # 8
moonpark
my brother my advice
1 pair 16cm jbl mid: zero price 180 tl (Doğubank) second hand: 120 tahtakale zaza han bottom floor
1 piece kicker 30 - 30 kicker bass: you find it very cheap from sahibinden.com 150-200tl
1 4-way Edison amplifier 700w can easily remove the 4 mid and 1 bass that I am using. price estimate of 150-200 max
I think if you can find sleds and cables in tapes, you can find a clean pionner tape with 100 TL USB.
Some say it was stolen, but the guys said they didn't steal: D
I bought myself
1.The piece bought clean usb pioner tape from 70tl brown
1.Affi edison, bass kicker, these wars have been taken down by the owner.
1 pair jbl 16cm mid rear panties 180tl dogubank.
1 pair kenwood had a normal 16cm column above it when i bought the car.
Mooring Cables Included 100TL (Next Auto CAGAT Murat)
And the sound quality I received was seriously satisfying
total cost: 575 TL
08.05.2020 17:56 # 9
yenice
I think Ali knows this job well and listen to his advice. but in order to help you better, I think you should first write the brand models and series of tape and existing columns.
my cd player, 16cm speaker at the front, 13cm speaker at the back were all the top series of pioneer. As for how I saw the benefit, yesterday I got the system installed. There are 20 subwoofer settings if there is none on the tape. When I assume that these settings are not turned off, or when I lower them to the lower level, the bass tears itself, but there is no action :) When you make these settings as needed, the bass finds itself. Without this feature on the tape, the system at the back will remain low.
The man looked at the tape and speakers first. The infrastructure is very good, now I believe that if I connect them to around 150 pounds of component sets, it sounds worse.
we just added amps and bass. I feel the press stroke in my waist while I am in the front seat :) It would be wrong to enter into a bad sound expectation of 300 lira materials :) it does not hit like a tin, it is very sweet and clear. The bass soundstream tarantula series connected 275 rms bass and roadstar amp. two of them total 300 lira. including the cabin or something. In addition, 80 lira cable set, we chose the fuse inside 80 amps or 40 lira cable set. but I said a guarantee.
If we connected 400rms of the same press, this time the forwell brand would connect the amp. it was appropriate. then only the price of the material was 450 lira. But what I wanted was a voice that would make the car wake up in the sky. so I did not prefer. But as I said, I am very very pleased with the bass I am receiving. Even this seems excessive to me now that I cut the bass settings in half. When I say the bass settings, I am not talking about the bass treble settings in the echo settings :) When the bass in the echo settings are at the lowest level :), when I turn off the other subwoofer settings and increase the bass in the echo, this time the bass comes to the columns and the sound inside is distorted at a high level. If the tape did not include these subwoofer settings, now I would get the sound and press half I received, maybe a lot less. Although it has the same bass and amp. So the job doesn't just end with high quality amps and bass. If possible, the tape difference performance if I could show it live. No matter how high quality bass and amps you plug in, the bass settings of the tape are very comprehensive and will provide additional quality. I see the live sample as I said
newish 2013-09-12 01:18:06
08.05.2020 17:56 # 10
cybermaniac
[QUOTE = Buying] Hodja good morning,
Thank you for your interest and interest in the master, thanks to you, I had some good knowledge, I did not look at my fault, but I had to suspend the sound system for now.
08.05.2020 17:56 # 11
Alicilik
HOcam is not pre-emptive, I can help whenever you want.
