Sound system help.
08.05.2020 16:37 # 1
cybermaniac
Friends, I joined you 3 months ago.2005 model 206 I finally got thank you :) I do not know much about sound system and a little modified, such as exaggerated exhaust body kit etc but I do not know much about these issues so please do not laugh where abart exhaust etc. etc :) :) I have no knowledge of such ignorant matters, there are no friends, friends etc. who can help me, first of all, I think a nice sound system that is not too expensive, but I would appreciate you to make suggestions as if it was a ready-made package system for what I did not know and where I could get it from me. Thank you very much.
08.05.2020 16:37 # 2
Bugra
If you are going to have an abart, you can cancel the last muffler from the simplest and get an abart from any exhauster. Between 100-150 TL. If you are going to install plumbing, there are most shopping sites on the net, you can get the package systems from there or you can get it done at the nearest plumber. & nbsp;
08.05.2020 16:37 # 3
cybermaniac
I want to get help with creating a preliminary idea because I do not want to be scared if I do not want to go around and get an idea, but I do not want to get involved. I am around Çeliktepe.
08.05.2020 16:37 # 4
cybermaniac
I found a ready system from Hepsiburada.com for sound system
price is around 1200.what is this system? Ready system is not too expensive?
08.05.2020 16:37 # 5
mucahidyasar34
bro, let me help you. Go to the Istanbul forum, there are sold as a set. Go listen to buy the one that fits your head. You come as a set cheaper and use a 2-year warranty. & Nbsp;
08.05.2020 16:37 # 6
Bugra
Now if the car's orig tape plays cd and there is a steering wheel control, I would change it. You connect the tape to the original tape. otherwise, if you install a tape recorder where you will have to cancel the steering wheel control event. In the plumbing business, I think that if 1000s of jbl bass, a team of mid and jbl amps are jbl, it would be more acceptable. but I don't know if you get help from more knowledgeable friends.
08.05.2020 16:37 # 7
cybermaniac
[QUOTE = bugrature] Now if the car's orig tape plays cd and there is a steering wheel control, I would change it. You connect the tape to the original tape. otherwise, if you install a tape recorder where you will have to cancel the steering wheel control event. In the plumbing business, I think that if 1000s of jbl bass, a team of mid and jbl amps are jbl, it would be more acceptable. but I don't know if you get help from more knowledgeable friends. [/ QUOTE]
What is the average price of
so what do they say? I want to sound bangir bangir, but now I want everything a bit more than the original. I want to make a very high cost. what is what you call mid team :)
08.05.2020 16:37 # 8
cybermaniac
[QUOTE = mucahidyasar34] bro, let me help you. Go to the Istanbul forum, there are sold as a set. Go listen to buy the one that fits your head. You come with a cheaper set and use a 2-year warranty. I want to have a sound, but what a little bit, what should I do accordingly, now I went to the exhauster, do not wear me an exhaust like a sir sir, so how do I make an exaggerated sound event?
08.05.2020 16:37 # 9
cey cey
If you want to get a silencer exhaust, you should remove it when you get bored.
08.05.2020 16:37 # 10
cybermaniac
[QUOTE = cey cey] you best get a silencer exhaust plug and plug when you get bored, remove the tip of the exhaust exhaust, wipe the ears of the ears, plug the tip again, continue the normal driving & nbsp; [/ QUOTE]
thanks bro:)))) & nbsp;
08.05.2020 16:37 # 11
Bugra
kompenent = mid guess the same. If the tape related with that tape remains the same, it's okay.
so these are some of the most pressed
08.05.2020 16:37 # 12
cybermaniac
Does this mean that the sound in the exhaust cuts 45%, so does it mean that a normal full abart sound will sound?
Is this sound system also reasonable as a brand? I know my questions may sound illogical, but I have no knowledge of these issues, unfortunately :(
cybermaniac 2012-03-05 18:09:50
08.05.2020 16:37 # 13
Bugra
I just researched them to give you an idea. & nbsp; You can see other ads in the same category on that site. You can also ask the seller whatever you want from the Ask a Question section. Do not exceed 100 liras for exhaust only, 700 liras for installation council. the categories in these prices will be enough for you.
08.05.2020 16:37 # 14
cybermaniac
[QUOTE = bugrature] and I just researched them to give you an idea. & nbsp; You can see other ads in the same category on that site. You can also ask the seller whatever you want from the Ask a Question section. Do not exceed 100 liras for exhaust only, 700 liras for installation council. It will be enough for you to research the categories in these prices. God bless you
08.05.2020 16:37 # 15
Bugra
I did my research on this & nbsp; site when you did not know about these issues. I asked the seller a question, I found out, but somebody who is in full work can still give more information. I wish that you can research and find information from this site. Good luck.
