sound system advice
08.05.2020 17:11 # 1
Burak
Friends who understand the sound system event, can you explain the ampwoffer and treble event? & Nbsp;
08.05.2020 17:11 # 2
Alicilik
The sound system proceeds in direct proportion to the efficiency you want to receive. The tones you want, the kinds of music you listen to, your budget affects the system structure. Get rid of the Pioneer-jbl king judgments first in the audio system. There are companies that produce much higher quality and user oriented products. They have proven themselves around the world and also the turkey slowly yayılıyorlar.vib to-Powerbass-JL-Hertz-vsöncelik always the main unit. The mechanism that produces the signal in the main unit. If the foundation is solid, the rest comes. The tape decodes compressed (mp3-wma-aac-flac) audio files with the help of codec and converts it into electronic audio signal. Tape outputs are generally divided into 2. (normal speaker outputs and RCA pre-outs). The normal tape output amplifies the audio signals with the help of the small amplifier on the tape and sends them to the speakers. This is Ac, ie alternating current. The voltage is high. RCA Pre-out sends the signal from the tape at low voltage. In this way, the sound is less resistant to the cable. The amplifier processes it and emits it as loud. When the tape is over, the work remains on the cables and the amp. The cable event is very important. Although the electric current in the vehicle is small, the quality of the cables used affects the sound. The feature and resistance of the cable can change the current. I would recommend using the products in cable sets that are famous in this regard. The shorter and better the quality of the RCA cable, the better the quality will be. The amplifier processes the drop voltage and outputs it as high voltage. It writes 1500w 2000w above the amps. I always ask me if this watt does this job, this car will jump rope: DPeak and RMS values. RMS (also called nominal) is important. Continuous business value is RMS. that means his amp does this job. The settings on the amp adjust the audio frequency, allowing you to pick up or block different tones. When it comes to speakers, coax and mid sets are usually used. Some people call it coax because of habits or hearing, some people call it mid (compensatory team) but there is so much difference between them. I use vibe black air 6 myself, the 16cm 2-way mid set itself is not as much as a 600w 85 "pioneer. Why are they giving so many different frequencies. Listen to the oval pioneer la calcical music and then you will understand with the mid set difference: DBu is confused for the RMS event but The RMS value of the amplifier should be equal to or lower than that of the speaker. Wouldn't it be upper but if you don't adjust properly, you can't burn the speaker too easily. Besides, cable insulation and quality are extremely important. When installing the first system (I did everything), some poor quality power I used a cable car, a car with a little muscle was burning, the system cable from the battery to the fuse, and the fuse from the fuse, and the fuse blown.
08.05.2020 17:11 # 3
Alicilik
I would like to tell you more detailed and illustrated, but for now you get an idea. I have a test tomorrow and Tuesday. If you get stuck, I would love to help you.
08.05.2020 17:11 # 4
Alicilik
Brother, I got a lot of information by trial and error. The sound system is very simple in electrical terms, like 2-3 cable disconnects, but the main sound event is very different. My advice to everyone is to have a more experienced person or expert work, no matter how much knowledge you have. I suffered a lot. I corrected it over time, but I had a lot of jokes. When I look at your amplifier, it says Peak values, I need to know the RMS value of 375w and measure the voltage value in some frequencies. To set it to: Firstly, you need 50 Hz at 0dB for subwoofer setting and 1 kHz at 0dB for other speakers. You can download these signals and many more from http://www.realmofexcursion.com/downloads.htm. Download and burn it to a CD. (I recommend downloading the files under the "Test Tones by Jmac" heading below in the link below, in the 0 dB WAV section) You also need a digital AC voltmeter. Then, in the link below, write "My amplifier is rated for" and your amp's rms output power and "watts into" section, in how many ohms. By clicking the "Figure Target Volume" link, our target voltage will appear in the pop-up window. (Turn off if pop-up blocker is on) A point to note; Enter the actual output power of the amplifiers called underrated, not catalog values. 1- Unplug the speakers from the amp. 2- Set the gain / input sensitivity setting of the amp to the lowest setting. Turn off settings such as bass boost and all crossover settings. 3- Adjust the volume of your main unit, max. Make 75% of the volume. (For example, if it goes up to 40, set 30) Flatten all EQ settings from the main unit, bass-treble, BBE, etc. turn off sound operations. 4- Connect the voltmeter to the amplifier's speaker outputs. Whether the voltmeter is on the AC side and 200V or close to it. Also, if you are using bridged mode, measure the voltage at these ends, not the stereo channels. 5- Start playing the necessary signal from the CD. And adjust the gain setting of the amp until it reaches your target voltage. 6- Reconnect the speakers and adjust the crossover and other levels for proper tonal balance. Let the hadith be easy ... [/ quote] Read this article. The setting made here is a technical setting. Make these embroideries a reality. It will surely make a difference.
08.05.2020 17:11 # 5
Alicilik
Thank you brother. I think you are using bass bridge. Try changing your channel. There may be a difference between the bridgeable channels in the stereo 4 channel amplifiers. & nbsp;
08.05.2020 17:11 # 6
Burak
master, when you buy a cable, is there any value to note on the cable?
08.05.2020 17:11 # 7
Alicilik
[QUOTE = mekuaes] master, when you buy a cable, is there any value on the cable that we should pay attention to, for example, you said things like rms for the amplifier? br>
Thank you.
When buying cables, do not buy 20-30t products sold on the sites or in any accessory.
The cable gauging system is called a little different Gauge or awg and the cable thickness increases as these values decrease. It is inversely proportional.
A quality 8 awg (ga or gauge) power cable is sufficient up to 1000w RMS. Specifically, it is difficult to look at the copper density and other components of the wire, but when you look at the cross-section of the cable, the wire density should be very high.
I was using 8ga but when the load could not meet the current, the cable fused until the fuse, the fuse had stopped, the car would burn. Now I bought a 2 gauge kit.
The photo below is a cross section of my old and yen cable. The new cable is about 1.5 cm in diameter
< br>
Do not use below 60A as fuse. 30-45 amps creates continuous trouble.
It is standard 5m as RCA cable. Try to get the golden tip which is possible silicon coating. Also, be careful with the ends, not to be easily damaged.
08.05.2020 17:11 # 8
hsnsnl
abi hello nbr,
do you want sound system recommendation: I looked at it, I saw it, I saw it, I would chose it as I wanted it. We chose the top series :) Let's come to the cable event, there will be a lot of cores that have already placed the photos, and the insulation silicon on the top will move (like the cable and the input cables should be carefully selected as you want). I will recommend vibe, infinity and powerbass as kompenant & nbsp; .. pioneer indispensable as tape ..
08.05.2020 17:11 # 9
hsnsnl
"If you remove two bass of 38 cm, this amp or 30 cm bass and what you need to add as a column" I need to put 2bass & nbsp; if you need to use it in the capacitor & nbsp; no need for them .. single press & nbsp; 30cm bass and beautiful branded vibe, infinity and powerbass & nbsp; If you think you are talking about oval cabins as a column, they are no longer bass in the vehicle, to get a medium for surronud sound, you said compenant, there is no bass in them, just sound (treble and music sounds, etc.) you put the bass in the back. .. you used compenant, anfi & nbsp; but you didn't put & nbsp; bass, you just get very live sound but you can't bounce that person's inside ..
08.05.2020 17:11 # 10
hsnsnl
tape beautiful amphitheater beautiful diosaan brother is a compenant left .. did you get 2 sets of compenant okmn :) oken :) compenant brands i will give up :) vibe, infinity and powerbass
08.05.2020 17:11 # 11
Alicilik
Vibe black air 6 at the front and infinity 5030
at the rear I use the powerbass s-12D as an amp for xetec xi 172.5
bass.
My tape deh 9350sd
I am very pleased with my system, there is only a sound to the front right stomach woofer and I will look at it at a suitable time. No matter how much I turn the sound on, the same hues hit the same way. There is no noise when you open it too, you continue to get the same quality.
As you said about your equipment, be sure to get rid of the prejudices like pioneer-jbl-kicker. Reviews
08.05.2020 17:11 # 12
FthArd
Hi guys, I need help on a topic & nbsp;
I recently bought Jbl Gto 1214 Br bass but I want to learn a suitable amp for this one too I don't understand these topics too & nbsp;
Power Handling Rms 300W
Power Handling Peak & nbsp; 1200 W
Frequency Response 35Hz-300Hz & nbsp;
Impedance 4 Ohms & nbsp;
Sensivity & nbsp; & nbsp; 94 & nbsp;
I'm looking for a suitable amp, I don't want to know what brand it needs to be and how much it needs to be helped. > Thank you .. & nbsp;
Reviews
08.05.2020 17:11 # 13
FthArd
Isn't there anyone who can afford it?
