Sound system
08.05.2020 19:46 # 1
Xhophera
Friends I have the Peugeot 301 Active model, I like the loudness of my age, but my father does not allow me to fill the trunk, I did some research, I did not find anything, the rear speaker is empty and I only have 2 speakers on the front console. My idea is to plug in a 400-500 w round speaker but a friend says it may not lift the tape. It says 2-3-4 output or something.
08.05.2020 19:46 # 2
usta307
My brother, you can't wear it according to your head. If my tapes have a certain w outlet, if you plug it on, the outputs will light up and if it is big, it should be suitable for the doors.
08.05.2020 19:46 # 3
Xhophera
I don't have a place in the doors anyway, my brother is a front console, the bidet is a back console, my question is, I don't know how much my original tape is
08.05.2020 19:46 # 4
samet206
Original tapes do not give very high output.I am not entirely sure that a 15-20 watt output is the speaker outputs of the original tape. In these values, the speaker is rare in the market, if you have original speakers, you can use it in the service or you can find the closest speaker to these values. It does not matter 500-600. The important thing is that the working power of the speaker is proportional to the output power of the tape. If the working power of the speaker is more than the output power of the tape, it is not possible to get good sound even if the output does not burn anyway. The speaker evolved when it switched to a 55-waiter tape.
08.05.2020 19:46 # 5
Xhophera
Should I take it to the tape recorder without any trouble so now :)
08.05.2020 19:46 # 6
mimit
Unfortunately, the speaker diameters that are troubled about the 301's sound system are quite low, above the normal effort to get nice sound, I do not remember the speaker diameters but it should be 13 cm, the friends of the 301 give precise information. There are products that are referred to as slim subwoofers, you can also put them in various kinds of luggage and place them in the armpits.
If you say how to get a nice sound, first of all, you can learn the speaker diameters exactly and have the right sized component set, two slim subwoofers, a 5-channel amplifier and mounting equipment. If you have a bass control feature in the amp, you can lower the bass level in family use and increase the bass level when you will ride yourself. Try to convince the car like this :)
08.05.2020 19:46 # 7
Xhophera
My speaker diameters are 16 cm round, I have 2 empty places in the back, 2 on the front chest, I thought, I would take it off and put it in 230 w or something.
08.05.2020 19:46 # 8
KILIC
[QUOTE = Xhophera] speaker diameters 16 cm round, I have 2 free places in the back, 2 on the front chest, I thought, I would take it off and put it in 230 w or something. . [/ QUOTE]
Unless he has an amp, he can not get the sound that he got from the original original speaker, by removing the original and replacing it with 500 instead. As his friends say, a slimbass and a mono way amp will do the job.
08.05.2020 19:46 # 9
imanpower35
it is not good to change this place without knowing it.
08.05.2020 19:46 # 10
KILIC
[QUOTE = imanpower35] it wouldn't be good to change this place without knowing it or not.
First of all, if you introduced yourself. Since the friend does not already know, he writes here to find out.
08.05.2020 19:46 # 11
Xhophera
Up !!
08.05.2020 19:46 # 12
barishrocker
I know that there are 13 speakers at the front, 16 at the back, but not every speaker as the iron is underneath at the back. If you are going to change the speaker, I recommend you to wear the amp. Otherwise, as you turn up the sound, there will be distortions as soon as you taste it.
08.05.2020 19:46 # 13
huseyin.celebi
Hello ,
my personal opinion is to go to a plumber, they sell very cheap systems, you can find the output of the original confirmation in front of the amphitheater at the back and the bass. If you want the baggage to be filled, you can put 20s of bass anyway. When you are going to use the trunk connected to the amphitheater, you will put it back home.
08.05.2020 19:46 # 14
ErkanPekergin
When I first received the 301 bookmark, I traveled with the original speakers for a month, the columns have a level of bad quality that would be very bad. I recommend you use tons of slim, if you want, you can use five middle class five channel amps to feed them.
