Sound system
08.05.2020 18:01 # 1
sulocan_5
Sony DSX-A30 (130TL) or PIONEER & nbsp; MVH-150UB? (135TL)
08.05.2020 18:01 # 2
sulocan_5
actual
08.05.2020 18:01 # 3
korkusuz202
2 side quality brands. Pioneer is my choice because, according to the information I got from a master, when the chip in sony tapes burned, it would be costly. I have 1400 ub.
08.05.2020 18:01 # 4
sulocan_5
thank you.
08.05.2020 18:01 # 5
Pioneer
08.05.2020 18:01 # 6
sulocan_5
I want to buy a front door speaker for the 206 XT. How many cm and which brand do you think should I buy? Appropriate (PIONEER & nbsp; MVH-150UB) & nbsp; Do you have a model?
08.05.2020 18:01 # 7
reality59
pioneer preference :)
08.05.2020 18:01 # 8
sulocan_5
what about the speaker ..?
08.05.2020 18:01 # 9
Alicilik
What is your expectation?
NHow do you think of a system? nbsp; Are you listening to the kind of music?
Are you going to use the amp?
What is your budget? Let's help you. Every manufactured good has a quality and a value. But whether it is good or bad varies from person to person. I like the vibe, you like powerbass, somebody else says jbl. Finally, Pioneer has assertive products in their classrooms. Let me know what you want and your budget. Reviews
08.05.2020 18:01 # 10
sulocan_5
My expectation is when I listen to music, I want the sound to sound good. I don't want to be too loud. (Medium bass) I generally like pop and stranger. But I listen to others too. When I take it out, let the control handle work on the original tape.
08.05.2020 18:01 # 11
Alicilik
[QUOTE = sulocan_5] My expectation is when I listen to music, I want the sound to sound good. I don't want to be too loud. (Medium bass) I generally like pop and stranger. But I listen to others too. (When I remove the tape, the original handle will work in the original tape). It will be nice if the tape has a remote control. (but it is not a must) I do not plan to strengthen the system in the future. Can I express my desire to know exactly? Look at it, it seems like I have a bit of a harsh expression in my article, but you have to give two options and skip it when you say it is not camel. These are the questions you are looking for. -blaupunkt-clarion also listened to all of them are very high quality but for some reason there is pioneer sympathy i also at the same time it is easier to optimize by vehicle.
If you want control, see the end50 series, these series are illegally introduced to the country by illegal means, they are cheaper than the 00 models - they are not guaranteed and controlled models.
I have been using 9350sd myself for 2 years. If the guarantee would be over already, thank God I had trouble.
When they want to buy normal series, they are guaranteed by dijicom and it is a little more expensive. Also, in normal series, the end of the socket is ISO type. You can plug it directly into the car. In other 50's models, the end is cut. You need to buy and solder the ISO socket. If you say I do it myself, 25cm 2mm makarom 30cm soldering and one soldering iron is enough.
Other than that, my advice for the speaker is to buy 165mm front and 130mm back if possible. If you are going to get 160 or 170 in front of them, be careful not to bend the case
When you buy a one-way speaker, intermediate tones kill other tones in high volume, so choose 2-way.
It is hard to make the pioneer 200e zero at the brand. If you say the back is not very important, you can take the front 2-way bit and put the one-way cheap back on the back.
08.05.2020 18:01 # 12
gngburak
I think that the region representative Alliance is an expert in the sound system .
I think heed what he said
08.05.2020 18:01 # 13
sulocan_5
Thank you very much for the information you provided. I will make my choice according to this information. The loudspeaker which is 165mm alone has never met. Is there a site that you know? Finally, would you recommend this advertisement?
& nbsp;
08.05.2020 18:01 # 14
yenice
I think you had another topic. I shared my own experience on this subject.
I don't know the exact model at the moment, there was a sony cd player on the vehicle. the speakers were Jameson on the back, JBL on the back, old-fashioned mid-quality speakers.
I replaced the stereo and all speakers with the Pioneer's top series models just like you. I bought the top series speakers of 13cm pioneer, 17 to the front and back to 230 pounds last year. I gave 350 lira to the cd player. As a result, there was of course a change in sound and bass, but if you say much has changed, no.
because the bass inside is insufficient, even if you buy the best quality speaker and CD player. If you increase the bass from the tape, this time the sound becomes a little distorted, and the speakers do not lift even though it is the top series. When the bass is lowered, the sound inside is pretty good, but this time the bass becomes zero.
so it is hard for you to correct the sound in your vehicle with the best quality speaker and tape. If I am wrong, Ali can also comment on my message. If you say amp + bass or don't kill my luggage, I think it would be more reasonable and healthy for you to reinforce with slim bass (armpit)
yenice 2013-10-28 14:08 54
08.05.2020 18:01 # 15
sulocan_5
Yes, you wrote an answer there. Of course you are more experienced in these matters. Since I am not sure, I need to ask several times. We will decide something now. Thank you very much.
08.05.2020 18:01 # 16
korkusuz202
If you are going to listen as a middle user, take the mid + treble kit in front ... If there are 2 oval speakers in the back, it is indispensable. I use it like this.
08.05.2020 18:01 # 17
sulocan_5
thank you.
08.05.2020 18:01 # 18
Alicilik
They made good advice on friends, but the budget is very important. I started with a sub-serial tape front-back speaker like you, now I'm listening to music with vibe. I invested a serious budget.
At a time friends shared this pioneerin set had a special set. The two speakers of the tape look at it, its price seemed good, and it will do a lot of work.
The products in the link are good, but I don't understand why money is mentioned right away. It didn't give me much confidence.
08.05.2020 18:01 # 19
yenice
[QUOTE = Appealing] They made good advice on friends, but the budget is very important. I started with a sub-serial tape front-back speaker like you, now I'm listening to music with vibe. I invested a serious budget.
If ali actually gives information about his current system, wouldn't it be healthier? I don't know if the current tape was the tape recorder, if we assume that it is a cd player and we think that there is a medium quality speaker on the doors, I think that instead of pioneer cd player and speaker, I think there will be no difference in sound and bass. Do you think I'm wrong?
08.05.2020 18:01 # 20
Alicilik
I know that Ramadan plays a cassette. Even if the ZAten cassette player is removed and inserted a pioneer tape, the sound changes a lot. Expectation and budget are very important. You know, you looked even stronger after the vibe and you got a strong active. If you get leon with the good in the future, maybe this will not satisfy you.
I couldn't find the pioneer set in my mind without forcing the budgets of my friend: with only a 2-way speaker set and a sub-series tape (the mosfet output is the same in all series. would be a little satisfied. ZAten amphitheater with tape is essential for good sound. Reviews
Page : / 2
