Sound system
08.05.2020 16:35 # 1
Gokhan38
hello friends i want to install a small way sound system in my car bosshman mid team magnat 1000 watt bufer bidet a lift will be waiting for your help
08.05.2020 16:35 # 2
Alicilik
If you think about kicker dx 200.4, a friend will satisfy you enough.
08.05.2020 16:35 # 3
Gokhan38
Do I need to buy an oval column or will I get a good sound with them
08.05.2020 16:35 # 4
Alicilik
The efficiency you want to get is important.
I also kicker ds 650.2 mid team in the front
mdf sponge in the back oval column
jbj 1100w bass and xetec 5 channel amplifier is not getting on the car again, the sound is not enough for me. >
the efficiency you want to buy material home is very important
08.05.2020 16:35 # 5
Gokhan38
I do not want to spend a lot of money, do I do business if I do not buy a colon or do you have other ideas
08.05.2020 16:35 # 6
kaderim@61
i will use a sister edison san anison brand anfi i'm admiring the number ten performance kenwood last model with the original cabin bass holds a total of 375 tl. you know you sound satisfied profit
kaderim@61 2012-02-10 17:02:35
08.05.2020 16:35 # 7
Gokhan38
I think the 2000 watt amphitheater of edison is 120 pounds or bde boshman mid team price will cause 75 pounds
08.05.2020 16:35 # 8
kaderim@61
If only anfi is needed, I would say to the general edison, they are trying to announce the names of a new company, so they have undertaken reasonable prices, quality products, and product warranty.
08.05.2020 16:35 # 9
Alicilik
first, the main unit is important.
No matter how much you are using it, if you are using the original tape, you will not get much efficiency.
What you use as the main unit is important. you will use the mid team in front of them. It is up to your materiality. My suggestion jbl gto 6508c
There are no factory speakers in my car at the back door. I did not touch either. I cut mdf spandes on the back and put oval pioneer 6997 speakers.
I used xetec xi-172.5 as an amp. Anfi 400tl
tape 400tl
front mid 260tl
back pandizot and hop. 280tl
cables 100tl
box bass 180tl
this is what it cost me. >
It will give you a very good acoustic with a mid-amphitheater with mid-front and back-to-pendulum ovals. The front mids meet your bass and treble needs very comfortably. It saturates the ovals on the back. Bass is not necessary if you are very curious.
08.05.2020 16:35 # 10
Gokhan38
I have a pioneer on the front doors.
08.05.2020 16:35 # 11
Alicilik
If you can, use the mid set if you are going to use the amplifier. & nbsp;
08.05.2020 16:35 # 12
Alicilik
this is my tape:
[TUBE] K_fAJd_Qadk [/ TUBE]
video belongs to me
ScHerZo 2012-02-10 17:16:43 < / editdat a>
08.05.2020 16:35 # 13
Gokhan38
yes i will buy an amp, i have never used mid team until this time
08.05.2020 16:35 # 14
Alicilik
whenever possible try to get systems with separate tweeters. When I hit the bass of the two-way ovale hard, the treble dies officially.
08.05.2020 16:35 # 15
Gokhan38
http://www.sahibinden.com/ilan/alisveris-elektronik-arac-elektronigi-arac-kolonlari-sifir- american-mali-16cm-boschmann-rv-6200-xt-kompenant-set / detail actually,
do you think you have any information about this product or oval? Is it a colon
08.05.2020 16:35 # 16
Alicilik
I recommend the 16 mid team. I have no idea about boschman, and for some reason I couldn't help link
08.05.2020 16:35 # 17
Gokhan38
If you look at the vehicle columns from Kayseri, there is 80 lira
08.05.2020 16:35 # 18
Alicilik
Yes, I looked at the market around. If you can, go to a place where you can listen to them.
08.05.2020 16:35 # 19
Gokhan38
how to connect this product and magnat buffer to the rear sponge and feed it with edison 2000 watt amphitheater
08.05.2020 16:35 # 20
Alicilik
I'll fix it, it's not a bufer. woofer.
If I think your car is 106, it may not be healthy to attach a woofer and mid team directly to its sponge. Mdf is a must.
edison anfi will do your job.
If you secure the pendulum, it will be nice. Reviews
Page : / 2
