Sound system
08.05.2020 15:58 # 1
friends, I bought a tape from my technician from pranha brand usb and sd card. The outputs should be 4 * 25. It gives a very good sound, but I put the original columns in my car, I have a roadstar brand column, I will buy a new column now, but if the tape outputs are weak, 16 cm of which brand column would recommend, it would be enough to press bass to get bass :))))))
08.05.2020 15:58 # 2
Instead of bass or column, I say compenent. but the tape outputs are very low, you can't get any efficiency so you better get it in the amphitheater
08.05.2020 15:58 # 3
normal pionner have round columns they do their job .... you by_ 2011-08-09 11:47:07
08.05.2020 15:58 # 4
What if the tape outputs are enough?
08.05.2020 15:58 # 5
bro, that's how it works .. you paid a few money now to that tape ??
08.05.2020 15:58 # 6
I gave 89 TL :)))
08.05.2020 15:58 # 7
http://urun.gittigidiyor.com/pıranha-charger-f-type-radyolu-usb-sd-mmc-kart_w0qqidzz40894166
this is the product :)))
08.05.2020 15:58 # 8
Look, even that tape is 4x40W.
08.05.2020 15:58 # 9
[QUOTE = Berkay] Look, even this tape is 4x40W.
If you look at it either, it says 4 * 70, and when you look at the real features, they said it wouldn't be as much as I said, I would have researched at most 4 * 25.
08.05.2020 15:58 # 10
[QUOTE = 60de106] http://urun.gittigidiyor.com/PIRANHA-Charger-F-Type-Radyolu-USB-SD-MMC-Kart_W0QQidZZ40894166
Look, don't get me wrong .. You get a tape for 89 TL .. Don't expect a lot of performance from that tape .... anyway, good luck ... normal column plug ... it will do its job ... if you raise the sound and listen, it's like 5-10 minutes you burn the outputs of the tape ... the best one is you get 5 channel amps 1 or 2 sets mid is better ... but the choice is yours ...
you by_ 2011-08-09 11:57:58
08.05.2020 15:58 # 11
[QUOTE = 60de106] [QUOTE = Berkay] Look, even this tape is 4x40W.
exactly .. my goal is not to abuse these brands .. but unfortunately do not believe the sound output in the features .. I had my first experience in kamasonic before :))) ...
08.05.2020 15:58 # 12
[QUOTE = by_ersin] [QUOTE = 60de106] [QUOTE = Berkay] Look, even this tape is 4x40W.
[/ QUOTE] I know that the king out pioneer didn't produce over 50-55w output either.
08.05.2020 15:58 # 13
+ 999 Thumbs Up
08.05.2020 15:58 # 14
Bavik
friends or I have to buy an amp, but I couldn't decide what to buy. I am looking for something a little cheap.
There is something called Edison http://urun.gittigidiyor.com/EDISON-ED-6004-4-2000WATT-PROFESYONEL-OTO-AMFI_W0QQidZZ42862368# description
Bide Jameson Die Bishey, which one of these things is alpine seems a little more reasonable to me but I don't understand how
08.05.2020 15:58 # 15
Be sure to look at sierra's lecture halls.
08.05.2020 15:58 # 16
Bavik
Thanks for your suggestion :)
08.05.2020 15:58 # 17
I bought a sniper from the net once my friends left
Now I am looking at one beautiful one. How did these columns look like?
08.05.2020 15:58 # 18
friends, do not you understand anyone or how do you think i got it but i dont know my good
08.05.2020 15:58 # 19
34sea45
I have used edison amps, but know that there are very few electrical leaks in the outputs of edison amps.
I am using xetec right now, it has a very successful performance, 4 channel amphith 1000 bass 1 set has alpine column, there is no interruption etc. There are 4 channels, bass works in a bit of column air but it is okay.
As for your problem, the kicker is a successful choice, but I do not think that your tape will save if you only provide the crossovers, provide the treble, do not just want to colonize.
08.05.2020 15:58 # 20
hakann83
I wish you could ask without asking my friend, according to the possibilities that you have now, take the sony or pioner 16cm column to the back, 13cm to the back, not to increase the cost, but it does not increase the cost of the work.
Page : / 2
