Sound problems at the doors and console
08.05.2020 19:22 # 1
Bob78
Hello friends;
I have sound problems with my new 3 door 2004 1.6 206 Ouiksılver, which I am very uncomfortable with.
The problems that I thought were caused by the defect of the front team before did not go away after maintenance.
  • On the smooth road, click when the glass is fully open, and also sounds from the door.
  • In addition, the bottom part of the steering wheel, the signal and the wiper arms, also sounds on the ground on the ground.
Has anyone experienced this situation before?
Are there places where I can disassemble and intervene? I wanted to consult you before removing.
Thank you from now.
08.05.2020 19:22 # 2
samet206
I think that other sounds are caused by loosening over time, I think that there will be no sound problems when the related parts are properly seated and the bolts are tightened. The issue of glass came to me. I had to disassemble it again, the problem was fixed, the windows are not making any sound anymore. The sound problems I saw in 206 were briefly on the glass, the trunk lock especially devastated me, the tailgate clips were broken, making the sound, the dashboard glass solution was found by compressing the paper, of course, only I know, right left I found the solution in all of the plastic floorings and sump plates in the windscreen poles. These are the ones that usually do not come across n parts.
08.05.2020 19:22 # 3
[QUOTE = samet206] I think that there will be no sound problems when other parts are caused by loosening over time, the glass issue came to my head when I opened the window halfway and started making noise when I passed the broken road, it was when the film was pulled out, this was when I pulled the stickers inside the doors to make the film, when I was attaching it. it was not fully seated, then I had to disassemble it again, the problem was fixed, the windows do not make any sound anymore. The sound problems I saw in 206 were briefly on the window, the trunk lock especially devastated me, the trunk lath clips were broken, the sound of the instrument panel was found by compressing the paper, of course, only secretly. I know, I found the solution in all of the plastic trims on the right, left windshield posts, and the sump plate. It is likely that there will be noise later on from the parts removed and installed. I have not come across any other sounding parts.
I agree with the samet, the vehicles need to get up and squeeze for a day, squeeze the pieces that are loose, do not get too careful when collecting apprentices in seconds, or they remain loose.
08.05.2020 19:22 # 4
Bob78
Thanks for the information, it is understood that we will spend a day for this. Smile
