Sound problem from the right wheel while parking
08.05.2020 19:53 # 1
iammanover
Friends returning with the car is okay, but when I parked, the sound of the mule in the right wheel began to sound.
08.05.2020 19:53 # 2
firstly welcome. I think it looks like a torsion. unfortunately the cost is between 600-800 TL.
08.05.2020 19:53 # 3
ALLEX
[QUOTE = sonerkyl] firstly welcome. I think it looks like a torsion. unfortunately the cost is between 600-800 TL. [/ QUOTE]
Soner is correct, but the rear wheel ball may be defective with torsion.
It will appear immediately while it is already being inserted.
The defective bearing only whispers during normal cruising, but as it is forced to move left and right during the maneuver, the balls inside the bearing make different sounds as they try to overflow their traces.
It will be helpful if you write down the problem.
Thanks to everyone who reads.
08.05.2020 19:53 # 4
iammanover
Balls of friends have changed, there is no problem, there is no problem, I got on for a moment.
Although I have 180 tires on the long road, there are no performance tires, there is no problem in this vehicle.
iammanov is 2016-06-30 14:15:31
08.05.2020 19:53 # 5
Can you check out the stepme cage, bro? And if you ride 4 people in the vehicle and try it, is it coming under load?
08.05.2020 19:53 # 6
iammanover
Soner Bey, I'm sorry, I have a mistake. Right, I forgot to write the front, not the back. Yes, we tried it. The only one does not notice 4 people.
08.05.2020 19:53 # 7
no matter my brother then have the damper mount and bearing checked. my skin is broadcast
08.05.2020 19:53 # 8
KILIC
the dungeon laughs like a chock But also have a check of the cornering stabilizer.
08.05.2020 19:53 # 9
ssakyel
my front wheels are doing sometimes, sometimes not, depending on the head.
08.05.2020 19:53 # 10
iammanover
even though we pay attention so much, the master has less holes in the moon like the moon you know, even in the month: D anyway iammanov is 2016-06-30 20:02:56
08.05.2020 19:53 # 11
red 206
My master, your problem is not on the tire, I am steering when parking, because the sound that you have broken is probably because it is from the steering hydraulics on the right side of the room, it comes to you.
