Sound problem after 407 clutch replacement
08.05.2020 19:46 # 1
mistercasper
friends last week, in a private service in Ankara, the press brake and flywheel of my vehicle changed and after that, a number of problems started after that ... when I was accelerating in my car, that is, when I pulled my foot from the gas, or started to be heard at a speed of 80 km when I shift the gear and leave the car to itself, There is a sound that I think is coming from the left front wheel or the road that continues up to km / h ... Also, it happens after the car has gone a little bit, this sound does not happen when the car is cold ... There is no change in the sound by pressing and pulling the clutch and brake, the sound coming out of the finished pad like a sound or a tire somewhere, it is a sound like it is a problem. see something He said not ...
08.05.2020 19:46 # 2
I think the car has winter tires as far as you can tell. Have the vehicle's bearings checked.
08.05.2020 19:46 # 3
mistercasper
Thanks for the answer ... I think that if the tires are only sound from the left side ...
08.05.2020 19:46 # 4
Efe-Pojo
please some logic. If these tires existed before the change, and it wasn't sounding, it seems ridiculous to believe in such a thing. most likely they couldn't do the assembly properly. the sound was coming from the tire to me, they had made the conversation when they couldn't adjust the brakes. you better go back to the installer and explain to them, because you know the pressure pad is very costly, intervene early so they can handle the cost before they grow.
08.05.2020 19:46 # 5
mistercasper
As I reside in Çankır, I will not be able to go to Ankara right away. I do not want to leave it in the hands of the same masters.
08.05.2020 19:46 # 6
If you are considering an authorized service, Fatih Peugeot is my advice.
