SOUND ON THE ENGINE
08.05.2020 20:04 # 1
pugmylifee
Hello friends
On my 1.4 206 vehicle, when I pressed the gas hard between 1200 and 2500 rpm recently, there is a clicking sound. There is no sound when the engine is cold, it starts to come more and more as it gets hot. at high revs (after 3000) the sound is cut off. I talked to a few people who said they hit the bed, there is a piston, there is a gap, etc. burning fat in the car blowing performance decline nothing trig recirculation just changed then it increased even more I would appreciate it if you help, it would be easy
08.05.2020 20:04 # 2
EMRE_R19
Check all the pulleys attached to the v-belt and the tensioner changed when the timing was changing?
08.05.2020 20:04 # 3
pugmylifee
Yes, the tensioner has changed, now we have detected something with friends. The sound is not coming from the engine.
08.05.2020 20:04 # 4
ggitaristt
I wonder if the guard plate on the starter or the exhaust side vibrates and hits somewhere and makes a sound? (It happened to me .. sahin .. colt..307 ..)
08.05.2020 20:04 # 5
Selox
Have the motor ears checked. If it can not hold the engine, it makes sound. When the rocking motor is hung.
08.05.2020 20:04 # 6
umut1001
Hello friends. My 206 started to make a noise. In the morning, when I started the car and started to move forward, there was a knocking sound (no matter how I describe it, we would squeeze the pet bottles into the tire of the bike. It is not very loud but it can be heard. .If he doesn't, he doesn't do it when he's back home. He's doing it on the way forward. umut1001 2017-02-01 21:52:29
08.05.2020 20:04 # 7
umut1001
[TUBE] was z1tpcgzsf [/ TUBE] sonerkyl 2017-02-02 15:58:30
08.05.2020 20:04 # 8
umut1001
What is the intermittent sound especially after the 13th second? umut1001 2017-02-02 15:54:13
08.05.2020 20:04 # 9
In the video, it sounded to me like a gearbox, hodja.
08.05.2020 20:04 # 10
umut1001
automatic car.Is there a lot of transmission costs?
08.05.2020 20:04 # 11
hope bey is understood in the video but if the sound is increased after the timing change, the problem may be caused by valve adjustment or eccentric bearings. If there is no knock, do not touch the gear in the vehicle at all, I think the best thing you can do for Şazuman is instant oil and filter change.
08.05.2020 20:04 # 12
umut1001
There is a slight knock, but it only happens in the morning, when the car is cold. The car is hot, it passes by click. Sometimes it does not pass from 2 to 3 on the car, I pass it manually. The Triger set changed last year.
08.05.2020 20:04 # 13
I think no shampoo oil and filter have changed, I think I would change it.
08.05.2020 20:04 # 14
umut1001
How much does it cost? Is there a place you recommend?
08.05.2020 20:04 # 15
Unfortunately, there is no place in Istanbul that I know. Our Istanbul members give advice. I think it costs around 250-350 TL. unfortunately, all of the gear oil does not change, it takes around 4 liters of oil up to 40 liters, the filter industry is around 100 TL, original 200-250 TL.
