Sound on partner engine
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Partner tepee
05.06.2021 23:21 # 1
Trb6161
My vehicle is a partner with a top zenit package in the 110 luk engine, it makes a loud noise at low speed, there is no problem when it is pulled at normal speed, there is no problem at high speed, it makes that noise at low speed and at idle. they said, does anyone have the same problem or has information, it would be very helpful if you could return. Thanks in advance
07.06.2021 14:47 # 2
Hello. If the problem is in idle, it may be what the masters say. There may be problems with encentric and thrusters. The reason for this is generally because of using different oils in maintenance. It would be better if you could take a video and post it for comments.
