sound on departure
08.05.2020 21:05 # 1
oguzcolk
First of all hello everyone;
My vehicle is 2002 model 206 1.4 colorline. When I pull my foot from the clutch during the first take-off in the vehicle, there is a hitting sound called plug.
Then they said the transmission wedge repeated and the room changed. But the problem still continues. What else needs to be changed? Ying Yang master or car :)
I would be very happy if you help on the subject. :)
oguzcolk 2018-11-30 18:31:37
08.05.2020 21:05 # 2
ismailkaya
how is it one time, do you wear it or does it intermittently at a certain speed?
08.05.2020 21:05 # 3
oguzcolk
It makes the calista in 1.2th gear as if the engine is shaking
It becomes more obvious when you go to Rollentide
08.05.2020 21:05 # 4
aykutbayram1996
the same problem is in my car, I did it from the great spinal gears, or I did what I did from the pressure grasp.
08.05.2020 21:05 # 5
oguzcolk
the problem I will bring to a service gives information
Thank you im.cok.
08.05.2020 21:05 # 6
If the wedges have not been replaced and the problem has not gone away, there is a problem with the potential pressure or transmission.
