Sound of Water Churning?
08.05.2020 15:08 # 1
ereneren
Dear forum users, the other day, when I realized that 307 was struck by the lights, another 307 crashed from behind, I pulled my foot from the brake and loaded it on the gas and there was no damage to my car, there were light scratches on the bumper ...
Starting from this incident now, the car has been lying for 2 days with rainy, I took off this day, and as I climbed uphill, I started to descend down with a sudden u-turn, and during this sudden turn, the car sounds as if it was shaking the half-full water demijohn, it only makes this sound in sudden turns and sudden stops. I wonder why?
By the way, the fuel tank is not full, even the gas light was new and no lpg.
thanks in advance ...
08.05.2020 15:08 # 2
klemann
The sounds of water coming from the heating system are generally.
08.05.2020 15:08 # 3
BuRCaK
Well, this sound only comes when the tank is full, but we haven't seen it after the last hikes. I didn't think of anything else. Yes, there may be a heating system. Get well soon
08.05.2020 15:08 # 4
Although sound can be heard from the heater, it does not make a big churning sound. The inner section of the heating hose is as big as your index finger. In addition, it is produced from thinner pipes in the heater core. however, if there is air left in the system, it squeezes water as it is in the home heaters and it makes water noise and this sound may increase when the gas accelerates when the gas is pressed. on the other hand, this sound is heard continuously in hard turns, etc. it is heard where it stops.
I don't think that the churning sound you are talking about will come from anywhere else than the warehouse. but one possibility is that there is water left inside the door. sometimes the bottom doors of the door are clogged. It starts to pour water inside. The sound of lacquer water is noticeable when the brake is applied or when the gas is pressed, etc.
08.05.2020 15:08 # 5
Eyup Duygun
This problem is very much in 206 diesels.
08.05.2020 15:08 # 6
slnysf
I tell you .. my uncle has albea right back door is knocked and made .. water is entering into the door in the rain and washing because the glass wick is open in the door. can. There was a contraction and water was taken in .. take care of the blows, kaoı luggage etc .. I hope it could be filled with water.
08.05.2020 15:08 # 7
motionemotion
Check the water drains of the front and rear doors. It is likely that water may have entered the door.
08.05.2020 15:08 # 8
ereneren
thank you to the friends who answered ...
In my opinion, it took water from a place instead of plumbing, but the place where it was hit is the same, so the condition of the cheetahs in the corner, the bumper connection points, somehow before I got hit, I also checked the inside of the trunk. If we say water is full, I know that the bumper is empty under six, so there is no space to fill with water.
