Sound of water
08.05.2020 14:00 # 1
206Quick
Right .. As I started cold in the mornings of friends, there is a sound of water, 15 seconds later, or something. What do you think is the problem?
08.05.2020 14:00 # 2
sinan-s
Just another problem ... It may be coming from radiator cores ..
08.05.2020 14:00 # 3
206Quick
I showed it to a master, I don't know it said it was normal in cold weather
08.05.2020 14:00 # 4
sinan-s
It is also necessary to ask the friends who used 206 quizzes. Did they live?
08.05.2020 14:00 # 5
[QUOTE = 206Quick] I just showed it to a master, I don't know if it was normal in cold weather [/ QUOTE]
It is dangerous to hear water in a fuel-powered vehicle. I can help if you give my friend more detailed information.
08.05.2020 14:00 # 6
hasimayaz
The problem is from the 99% radiator. Peutos automatically take the air in the water. however, radiator or hose blockages may cause noise. Also, you should use red antifreeze in your vehicle, or green antifreezes can cause serious corrosion problems in our vehicles.
Your vehicle has a sensor for the water level. If there is a dangerous amount of decrease, it will give stop warning and sound. I think it's not a problem.
08.05.2020 14:00 # 7
[QUOTE = hasimayaz]
Well, the last time I heard the sound of water, no good things happened Haşim Abi Cry
08.05.2020 14:00 # 8
206Quick
I use eet green antifreeze + radiator spare water tank, the clamp on the end of the hose disappeared: S I said that I had it stuck for now, but the water was dropping, I said 100 ytl.
08.05.2020 14:00 # 9
How Beautiful Is My Brother Authentic :)
There is Air in the System
08.05.2020 14:00 # 10
[QUOTE = 206Quick] eet I use green antifreeze + radiator spare water in the hose at the end of the hose disappeared: S I said I stuck it for now, but I thought it was 100 ytl.
If you research a little bit, you will definitely find it, my friend.
08.05.2020 14:00 # 11
hasimayaz
No handcuffs can not be 100 ytl sister .. a little more detailed or if you take a picture and send it more clearly ..
When I last used green antifreeze, I took the thermostat in my hand.
08.05.2020 14:00 # 12
206Quick
the clamp is not 100 ytl, the complete hose is not sold at that price. The clamp is not sold individually.
08.05.2020 14:00 # 13
206Quick
The friends I have mentioned are 206 on top of the clamp radiator tank ...
08.05.2020 14:00 # 14
hasimayaz
In this case, your hose is unchanged. Nothing to say .. even I think get rid of the green antifreeze ..
08.05.2020 14:00 # 15
ixtanbul
I have that same problem
08.05.2020 14:00 # 16
There is air in the heating system. You need to get air from the radiator. It is fixed with experience.
08.05.2020 14:00 # 17
[QUOTE = dejavu] there is air in your heating system. You need to bleed air from the radiator. It is fixed with experience [/ QUOTE]
Please open the dating title. It is fixed with experience!
08.05.2020 14:00 # 18
TOLGA
this is not a fault for 206,
It was heard to be seen in 106s,
