sound is coming from behind
08.05.2020 17:32 # 1
onur07
Even when the vehicle is on a flat road, it almost makes a sound .. when it is pulling from the pits of small pits, there is a sound of crest. why i am not sure but can i be an absorber
08.05.2020 17:32 # 2
onur07
I stretched my hand out of the rear wheel, the lower part of the shock absorber moves left and right, as there is space, is it normal? I wonder if he makes the sound while driving.
08.05.2020 17:32 # 3
_ali_
The exhaust may be shaking.
08.05.2020 17:32 # 4
samet206
There is a problem with the back teams. you may also have shock absorber wedges in mind ...
08.05.2020 17:32 # 5
mistik
possibly from rear torsions.
08.05.2020 17:32 # 6
onur07
the exhaust is shaking more than necessary yes, it is attached to the ground, but it has a stretch like a rubbery material, it plays the exhaust to the left, I think there will be a sound coming from it as it turns out ... to master?
08.05.2020 17:32 # 7
onur07
When you look at torsions, I looked at the Internet, as you probably thought, because when I checked that part from the play, what would I expect to change or repair?
08.05.2020 17:32 # 8
arachnid
Makes it in squeaky sounds. Holds 400-500 TL
08.05.2020 17:32 # 9
onur07
it sounds just like that squeaky sounds ... occasionally ... thank you
08.05.2020 17:32 # 10
ufuk91
Coming from 99.9% torsions, my teacher used to have chronic problems of 206's. I have been trying to ride without listening to those voices for 4-5 months, but now it is my life, but as they say, it has a cost of around 500 liras. No problem, I am using it for now, but as if I was dragging on the asphalt with a seat, the road is a little broken, you get a crackling crush and you get a sound from the ground, as if you have thrown a ball in an empty tin, you can notice it when you use it by opening the windows "Angry"
08.05.2020 17:32 # 11
onur07
You have expressed all my trouble completely in the same trouble! It is a kind of trouble that will make me crazy, but I hope that the situation is not good, I hope it will not hurt to use it any more.
08.05.2020 17:32 # 12
peugeot22
A common problem in peugeot is torsion.
After the torsion breaks down, the rear wheel will begin to skew with some camber and will begin to rub into the tire fender over time, which means less harm and expense when
is treated early,
but it has a 500 lira loss :(
08.05.2020 17:32 # 13
onur07
There's a little bit of trouble right now, until I don't have to ride it, I don't want to have a bigger problem, I can't handle it: /
08.05.2020 17:32 # 14
Alicilik
[QUOTE = honor07] There's a bit of trouble right now, if I don't have to ride it, I wouldn't want it to get bigger, I can't handle it: /
Have you checked the spare wheel?
08.05.2020 17:32 # 15
onur07
I did not check? What kind of problem could it be?
08.05.2020 17:32 # 16
onur07
I took my vehicle to the service today; determined as the problem of torsion, when I said another piece of balls that will be changed, I forgot its name if it had to be done on the lathe if it was not worn too much .... how do you think it came? and if the lathe process is not very worn, he gave the answer to the question of 1500 TL.
