sound is coming as the car speeds up |
| 08.05.2020 18:16 | # 1 |
I changed the oil and filters of my 206 vehicles. one day later, as the vehicle accelerates, the sound of tıssssss sounds like the air blowing in proportion to the gas. the master said there was no problem with the engine but could not find the reason. what do you think and how can i get rid of this sound ???
| 08.05.2020 18:16 | # 2 |
the sound sounds as if it comes from inside, by the pointer. I do not think it is exhaust, not excessive. and it occurred just after maintenance. |
| 08.05.2020 18:16 | # 3 |
exactly. Another friend said, the air filter is not seated properly or may be loose. gotta take a look. thanks. |
| 08.05.2020 18:16 | # 4 |
ahmet_bjk |
If the sound starts to come after maintenance, it is most likely caused by an incomplete or incorrect operation during maintenance, the master performing the maintenance should check the disassembled parts from the beginning. |
| 08.05.2020 18:16 | # 5 |
yes probably it is caused by the caregiver. i will go today let's look again. thank you ahmet sagol |
| 08.05.2020 18:16 | # 6 |
I had the same problem, can I learn how you solved it after maintenance |
| 08.05.2020 18:16 | # 7 |
ahmed206 |
Aaaaah, those masters are absent-minded. How many times have I waited at the beginning and corrected his mistakes without breaking, "Master, wouldn't it be better if we did this?" The bit. These masters master the man.
| 08.05.2020 18:16 | # 8 |
[QUOTE = ahmed206] Aaaaah those masters are those who do the scavenging work. How many times have I waited at the beginning and corrected his mistakes without breaking, "Master, wouldn't it be better if we did this?" The bit. These masters master the man. [/ QUOTE] aynenn |
| 08.05.2020 18:16 | # 9 |
friends, neither the problem was solved nor the source of the problem was understood. I went back to the master who was doing the maintenance, but only the word he said was not an important thing, nothing could happen with this sound ... I quarreled, I went. when i am available i will go to another master. |
| 08.05.2020 18:16 | # 10 |
I have the same problem, as the cycle rises, the sestw rises, 2 reasons said to me either I did not make it from the air conditioning balls or the steering pump, but it did not make 80 direcion pumps yet, it would reach 200 liras even if it cost 155 liras and 50 liras. According to the saying of the master, ins. If not, it is between 1000 and 2000.
