Sound insulating inside the door of my 307 vehicle
08.05.2020 15:00 # 1
sercinho
tool on and the back door in the second column has a column of mounted, floor hard plastic origin takes k is them slid quality of a capillary in my column tactics are beginning to flicker does not come ever host an audio door plastic of the interior is completely empty, now I have an idea there I want to fill out the doors of the inner part of what would you recommend?
I have to fill the door in order to fully flush the gap inside, at least this is the method I found, or what rice would you like to hear if you have an offer to get performance from the door columns without breaking the vehicle's originality?
08.05.2020 15:00 # 2
reserpin
I think something will work like slikon. I think there are arcs that will help you in more detail.
08.05.2020 15:00 # 3
muratgulen07
colon okadar titretiyomu :) what is the brand anfilimi anaphysmia bass how? Valla bass wurs, shake me, I'm bored, I will remove the treble and throw the originals in my head.
08.05.2020 15:00 # 4
sercinho
pıonner component sound I want to get better sound and cut the sound coming from plastic parts
08.05.2020 15:00 # 5
[QUOTE = sercinho] ponyner component amplifier I want to get better sound and cut the sound from plastic parts [/ QUOTE]
I couldn't fully understand what you said. Do you feed the component sets with a separate amplifier or do you think the crossovers of the component set are the amps? Because the separators are the amphitheater, I said that pain
the cecol 2010-12-28 13:01:21
08.05.2020 15:00 # 6
sercinho
I do not have a separate amp.
08.05.2020 15:00 # 7
hmm, if you are feeding with a beautiful amp, you will get good sound. Of course, when the sound pressure increases, the right and left parts can trim. These annoy you as much as you have. In some vehicles, the plate click sound heard from the outside is heard even if it is not heard inside. As bass hits, it makes you crap. I'll be scabies too. the cecol 2010-12-28 14:58:32
