Sound From The Vehicle [Video]
08.05.2020 17:21 # 1
KenBlockJR
Hello friends. As the cycle is falling, there is a sound like cat meow. what could be the reason for this sound?
[TUBE] qrbxlp3sap of & [/ TUBE]
08.05.2020 17:21 # 2
xMEGANx
TURBOOOOOOOOOOOOOOwwwwnnnnnnn :) & nbsp; sounded nice. & nbsp;
Note: No problem, but as if it is in the background I seem to hear an old Timing set sound.
08.05.2020 17:21 # 3
Serkan
Is there a turbo in this vehicle?
08.05.2020 17:21 # 4
KenBlockJR
no turbo problem anyway :)
vehicle 206 roland garros 1.6 petrol
08.05.2020 17:21 # 5
Zagorka
Since there is no interesting Turbo .. & nbsp;
08.05.2020 17:21 # 6
Burak
Let me give the expected answer, then there is a cat in the engine: D
08.05.2020 17:21 # 7
Alicilik
[QUOTE = mekuaes] Let me give the expected answer, then there is a cat in the engine: D
I watched the video I watched the video and it passed me.
Our bmw does this, but there is a propeller between the 50cm motor and the radiator in that kitter that makes a sound like a donunce plane.
a little bit of water when the gear is not gone, it sounds like it is like ending, so it is also interesting. Timing is an idle link probably
08.05.2020 17:21 # 8
impact
cat is cat .. :)
08.05.2020 17:21 # 9
aykut p.
Well, brother, I don't understand the engine or something, but the sound may be a bit of an airborne piece, so when we whistle with the bag when it is small, it sounds very similar to that, it might sound like this other high probability obsolete timing set
08.05.2020 17:21 # 10
xMEGANx
If Heemmm is gasoline, it's sure there is something missing in my mind.
08.05.2020 17:21 # 11
cerci07
v not from apricot ??
cerci07 2013-02-13 23:13:24
08.05.2020 17:21 # 12
KenBlockJR
[QUOTE = cerci07] v doesn't come from apricot ??
it seems to me too, let's try to show it in 1 month
08.05.2020 17:21 # 13
oozcan42
There may be an air conditioning engine. Turn on the air conditioner and give it a try.
08.05.2020 17:21 # 14
emin15
v belt tensioner bearings are broken, remove v belt try, if the sound continues, timing bearing or recirculation
08.05.2020 17:21 # 15
Demir
Check the engine or air conditioning belt ... Also on the engine pulley ...
