Sound from the V-belt?!
08.05.2020 18:22 # 1
candanxyz
Friends may have (non) voices from the V-belt related to scorching with tension and looseness during the winter months.
In this way, the friends who have problems can sprinkle 4-5 pieces of chalk, which we write on the chalkboard we know, by sprinkling the mechanism that causes the belt to turn while the engine is stopped.
The sound will be cut off.
I wanted to share with you, those who have this kind of problem can try.
08.05.2020 18:22 # 2
tetik-soner
thanks..
08.05.2020 18:22 # 3
halilefe
I said I would change the strap too, I gave up, chalk is an experience. Tongue
08.05.2020 18:22 # 4
mami202
This practical workaround sounded familiar. We had a 20-year-old machine in the workplace. Normally the speed indicator would appear as 5 thousand, but the machine would operate at 3 thousand cycles. :) Those who are cold to find chalk can pour powder and try 2 sides as a result, good evening pleasant driving.
08.05.2020 18:22 # 5
halilefe
Let's try powdered brothers, let's see tomorrow.
08.05.2020 18:22 # 6
Turgay_66
Wow :)
08.05.2020 18:22 # 7
206cc57
Could you take a picture of exactly where you poured this chalk powder / powder, if it is possible .. sometimes there is a sound like a bird crow, maybe a solution from the strap .... 206cc57 2014-03-26 14:17:24
08.05.2020 18:22 # 8
candanxyz
Needing a photo is very simple.
Put 3.5 pieces of chalk into powder, sprinkle the mechanism with your hand while the vehicle is at a stop.
Of course, if water enters in rainy weather, it may lose its effect.
08.05.2020 18:22 # 9
C@GL@R
If my brother said well, I managed it for 1-2 months with your method.
C @ R @ GL 2014-03-26 15:54:46
08.05.2020 18:22 # 10
serkomser
How do you think if we spray rust remover? In the mornings, after the belts change, I sing a bird in the hood :)
08.05.2020 18:22 # 11
sezar206
The sound of the bird is ball defective. It's not a very paki thing. You can't remove it with such dust.
08.05.2020 18:22 # 12
tetik-soner
There is a gurgling sound like water in me.
08.05.2020 18:22 # 13
tolga.onal
I also have a different sound like a squeak when you turn the steering wheel and gas when idling when the car first runs when the car is cold Is this related to the V-belt? it feels like it came from under the car through the middle of the car, but I don't know what it is.
08.05.2020 18:22 # 14
samet206
When I heard the powder, chalk is different methods for the first time but I think wd40 is the most professional :)
08.05.2020 18:22 # 15
_ali_
[QUOTE = fatihpekgoz] The sound of the bird is badly ball. It's not a very paki thing. You can't remove it with dust like that. [/ QUOTE]
True, the cik cik sound comes from the ball team, and it is sold as a team, the original 200-250 TL.
08.05.2020 18:22 # 16
kuscu38
[QUOTE = candanxyz] Friends The V-belt may have (non) voices related to scorching with tension and slack during the winter.
Thank you, my teacher, I had such a problem, it was passing by when the engine was warming up.
08.05.2020 18:22 # 17
kuscu38
[QUOTE = samet206] chalk is different methods for the first time when I hear powder but i think wd40 is the most professional :)
I tried it, it did not work for me .... maybe the trouble in me was different!
