Sound from the steering wheel when it's cold
08.05.2020 21:22 # 1
Kartalilhan91
When the engine is turned, it makes sound when turning the steering wheel. There is no sound when it gets hot. The master said, use it like this, but I couldn't trust anyone living the same problem? How did you find the solution?
08.05.2020 21:22 # 2
omerb
hello sound sound squeak.?
If so look at the bottom of the steering column, that is, the clutch pedal. There is a rubber protector where my steering column enters. It may also have a rubbing sound. If the sound comes from there, remove it and apply silicone grease. I set out because the sound says it stops when the car gets hot. It does this in cold weather.
But if the sound comes from the inside, there may be a problem with steering hydraulic equipment. This problem usually does in hot oil. I know she won't do it in the cold
If your problem is solved, please do not forget to post in the forum.
08.05.2020 21:22 # 3
[QUOTE = omerb] hello sound in the form of squeak.?
+1 Clap
