SOUND FROM THE STEERING WHEEL AND NO REMOVAL
08.05.2020 17:01 # 1
t.tuncel
Hello friends, my car stopped, and I couldn't understand that it started to give the faults one after another within 2 days ...
firstly, when I started to move the steering wheel to the right or left, it sounds more disastrous than the creak of the door, but there is no sound after starting to move, regardless of the position of the steering wheel. the steering wheel starts to sound with the application of force and there is no reduction in steering hydraulics ...
When my other problem was actively used, when I started again after an average of 45 km, the vehicle did not exceed 80 and normally I could see 170i in lpg. May this cause a decrease.
AND WHAT IF I HAVE AN EMERGENCY ANSWER TO MOVE THE VEHICLE IF YOU HAVE AN EMERGENCY ANSWER TO TRAVE TO THE CAR AT 3 HOURS?
08.05.2020 17:01 # 2
berk2309
How can the sound of the engine be on the coach steering pump, malfunction or on the shaft & nbsp;
08.05.2020 17:01 # 3
t.tuncel
My teacher had opened a topic before, sometimes as soon as I started, as if the wheezing works like a tractor, they did not find any malfunction that I took to the service because it stops and restarts it. It was said that it was burning LPG and when I started working on gasoline, the fault light went out after a while ... ......
08.05.2020 17:01 # 4
berk2309
some friends were like the tractor they might have been sourced from triger when they last changed & nbsp;
08.05.2020 17:01 # 5
t.tuncel
I do not know when the vehicle has been changed for 2.5 months. I just made a 25 km road. The steering wheel made a last minute sound.
08.05.2020 17:01 # 6
drakman
Interesting
08.05.2020 17:01 # 7
peugeotttt
my friend you look at the oil, as you said in the car, I was making my voice turn the steering wheel while I was looking at the service, the oil was running low from it.
08.05.2020 17:01 # 8
t.tuncel
peugeotttt thank you for your suggestion When reading the article, something came to my mind.
the vehicle's oil steering power box is full but there may be a blockage in the hoses, or should they tell friends who are experienced in this regard?
08.05.2020 17:01 # 9
peugeotttt
I do not know how much but when I was turning the steering wheel, it made a sound like a creak of the door.
08.05.2020 17:01 # 10
qetzman
If your friend is making a sound while turning the steering wheel, you need to take the steering pump for repair. There are approximately nail-shaped rectangular metals in the pompom, which are called a blades, and they work in what looks like a thick bracelet called a shirt. this shirt is probably drawn. If the blades are not damaged, what we call shirts need to change, you change the felt when you change it. I guess the situation will improve. I think it will be between 80 and 120 TL.
