Sound from the steering wheel ...
08.05.2020 14:56 # 1
desert197
When my friends start to turn the steering wheel to the right when it is at a speed of 90-100 km on my 206 x-line car, it sounds like a cricket's voice. It starts after 20 km of roads. This is what you may have. This problem started after the right swing changed, but the master says it is not. Can there be a steering wheel? Waiting for your help .... Thanks ....
08.05.2020 14:56 # 2
Muhammet CAKIR
had the same problem on dating this & nbsp; I think there is a vehicle in the vehicle, I think, when I rotate the steering wheel, it makes a bitter vizr sanki wipe the glass, it works like it works. I did not have the opportunity to have it checked. When I look at it, I will inform you on the map.
08.05.2020 14:56 # 3
karacocuk
I do not know much about 206. I do not know if the hd pump is electric or if it is turning with the help of a belt. I have to explain the trouble
08.05.2020 14:56 # 4
Kifanhom
One of the chronic problems of the 206's is the steering gear, but it is interesting that this sound appears after the swing has changed.
Take it to the master wearing the swing and check it again
08.05.2020 14:56 # 5
deniz_206
The steering box has a defective space. It happened to me. The same event is getting the space. A nice master, then the sound is cut off.
08.05.2020 14:56 # 6
desert197
thanks for your interest
