Sound from the steering wheel
08.05.2020 14:11 # 1
Celalettin
Hello, Haşim master. When I turn the steering wheel 10 degrees to the right or left (while walking or working at idle), a sound started to sound. It is not like a whistle or something. I am very careful why I am bored. Greetings and thanks in advance.
08.05.2020 14:11 # 2
hasimayaz
coming from the steering wheel or the tire? do you do it at high speed?
08.05.2020 14:11 # 3
Celalettin
It comes between the steering wheel and the body link. I didn't check it at high speed, but it's like a little touch or a momentary rubbing sound.
08.05.2020 14:11 # 4
Celalettin
I tried it at high speed a little while ago. It sounds like a momentary contact with a metal tongue. When I turn it in both directions, it has the same sound. It is not from the steering wheel but from the plastic connection.
08.05.2020 14:11 # 5
bbcb
I guess it would be useful to remove the steering wheel from the ball in the center of the steering wheel and have the balls checked.
08.05.2020 14:11 # 6
Celalettin
Thank you, my friend.
08.05.2020 14:11 # 7
the same problem is on the bnd when I break it to the left, it sounds like a plug
08.05.2020 14:11 # 8
Eleanor_
brother, if you found the problem, you better share it, but the same problem is in me.
08.05.2020 14:11 # 9
BuRCaK
I have a very humming noise. I'm afraid that the steering pump is failing. more than 24000 cars
08.05.2020 14:11 # 10
Eleanor_
I am afraid of the pump too, I hope it won't cause any problems
08.05.2020 14:11 # 11
bbcb
If the pump seems to be failing or if it fails, there will be an obvious hardening in the steering, that is, the steering is black steering. If this current power is broken for the power, do not get it repaired.
bbcb 2010-04-16 19:35:11
08.05.2020 14:11 # 12
mechnegg
I have the same problem, friends .. I would be glad if you can help ..
