Sound from the steering wheel!
08.05.2020 20:16 # 1
oguzhankozler
I am a new member of SA friends, I do not know if I opened the subject to the right place, but I have a question.
08.05.2020 20:16 # 2
KubilayBozaroglu
Hello, I had the same incident in me, there are different reasons for this, but mine's steering fluid was completely gone from gasoline to 20 lira castrol gearbox oil, at the same time, the steering fluid is pouring, I poured it right where I stopped, and for some time I went to check the liquid of the vehicle. It can also be caused by the direllion box or from running out of mechanical parts.
08.05.2020 20:16 # 3
oguzhankozler
You're right, I turned it on and looked at it, but I had the oil, I just changed the pump, now I took it now.
08.05.2020 20:16 # 4
sevozgur
I have the same problem. The peugeot services with idiot call this as normal. Liquids are full but there is a problem with the hydraulic steering or the pump. There is no problem.
08.05.2020 20:16 # 5
hzr206
If you want to replace it with a new hydraulic oil. The hydraulic fluid of my vehicle was old and decreased, and the noise was greatly reduced.
08.05.2020 20:16 # 6
yigit_dark
I opened the subject and examine it. If they have the same sound, they said to me in the shock absorber pads. Let's change the shock absorbers, said the oil missed. I am waiting right now, it does not harm the driving, it does not pose any danger, but this noise disturbs me. Because there is a clear voice in turns.
yigit_dark 2017-03-26 18:10:54
