Sound from the steering pump
08.05.2020 17:31 # 1
leffe
At a point where the steering wheel of the vehicle turns a few degrees to the right, a fine whistling sound is heard from the front right. I heard there was a chronic problem in the 307s, the master said dont worry. Steering pump replacement is very expensive after all.
Another master suggested changing the steering oil, I think it has the same oil in 10 years.
The question is: Does the change of oil have an effect? ? I wonder if I try not to mind it, will it cause any problems in the future?
08.05.2020 17:31 # 2
samet206
Whistling sound can also be made from disks or balls.
08.05.2020 17:31 # 3
emre_akdag
It's time to change the oil. The whistling sound is chronic ... even in Bipper models. don't worry.
08.05.2020 17:31 # 4
leffe
You just endure the groove because you like a chick, and having a Peugeot is like this .. you endure nonsense :) what can I say?
08.05.2020 17:31 # 5
qqyyxx
Have the steering pump chock checked.
